need help with skps configuration+pic16f628a
Postby wheresaly » Tue Mar 26, 2013 1:25 am
need some help with the coding.
im using MPLAB 8.84 and Hi-Tech C Compiler 9.83 (lite mode)...
there is some problem that i cannot solve.
hope someone can check the coding for me..
fyi. i just use the ps2 to control the movement for forward, reverse, right n left..
Code: Select all
//   include
#include <pic16f628a.h>
//   configuration
__CONFIG ( 0x3F32 );
//   define
#define motor_fwd   RA3
#define motor_rvs   RA2
#define motor_rg   RA1
#define motor_lf   RA0
//skps protocol
#define   p_select      0
#define p_joyl         1
#define p_joyr         2
#define p_start         3
#define p_up         4
#define p_right         5
#define p_down         6
#define p_left         7
#define   p_l2         8
#define   p_r2         9
#define p_l1         10
#define p_r1         11
#define p_triangle      12
#define p_circle      13
#define p_cross         14
#define   p_square      15
#define p_joy_lx      16
#define   p_joy_ly      17
#define p_joy_rx      18
#define p_joy_ry      19
#define p_joy_lu      20
#define p_joy_ld      21
#define p_joy_ll      22
#define p_joy_lr      23
#define p_joy_ru      24
#define p_joy_rd      25
#define p_joy_rl      26
#define p_joy_rr      27
#define   p_con_status   28
#define p_motor1      29
#define p_motor2      30
//   global variable
//   function prototype
void init(void);
void forward(void);
void backward (void);
void reverse (void);
void left(void);
void right(void);
unsigned char uart_rec(void);
unsigned char skps(unsigned char data);
void skps_vibrate(unsigned char motor, unsigned char value);
//   interrupt prototype
//   main function
void main(void)
   unsigned char up_v, down_v, left_v, right_v;
   init();         //initialize microcontroller
   stop();         //stop all motor
      //button control for mobilility
      if(skps(p_up)==0)               //check "up" button
         forward();                  //move forward
      else if(skps(p_down)==0)         //check "down" button
         backward();                  //move backward
      else if(skps(p_left)==0)         //check "left" button
         left();                     //rotate left
      else if(skps(p_right)==0)         //check "right" button
         right();                  //rotate right
// initailization
void init()
   // Tris configuration (input or output)
   TRISA = 0b00001111;            //set RA0-RA2 pin as input,other as output
   TRISB = 0b00000110;            //set RB1-RB2 pin as input, other as output
   // TMR 0 configuation
   T0CS = 0;
   PSA = 0;
   PS2 = 1;                  // prescale 1:32
   PS1 = 1;                  //
   PS0 = 1;                  //
   TMR0IE = 0;                  // TMR0 Interrupt
   TMR0 = 0;
   //setup USART
   SPBRG = 0x81;                  //set baud rate to 9600 for 20Mhz
   BRGH = 1;                     //baud rate high speed option
   TXEN = 1;                     //enable transmission
   TX9 = 0;
   CREN = 1;                     //enable reception
   SPEN = 1;                     //enable serial port
   RX9 = 0;
   RCIE = 0;                     //disable interrupt on eachdata received
   // enable all unmasked interrupt
   GIE = 0;
   PEIE = 0;
// uart function
void uart_send(unsigned char data)   //function to send out a byte via uart
   while(TXIF==0);               //wait for previous data to finish send out
   TXREG=data;                  //send new data
unsigned char uart_rec(void)      //function to wait for a byte receive from uart
   unsigned char temp;
   while(RCIF==0);               //wait for data to received
   temp=RCREG;
   return temp;               //return the received data
// skps function
unsigned char skps(unsigned char data)         //function to read button and joystick
{                                    //information on ps controller
   uart_send(data);
   return uart_rec();
{                                    //function to control the vibrator motor
   uart_send(motor);                     //on ps controller
   uart_send(value);
// motor control function
void forward ()
   motor_fwd = 0;
   motor_rvs = 1;
   motor_rg = 0;
   motor_lf = 1;
void backward ()
   motor_fwd = 1;
   motor_rvs = 0;
   motor_rg = 1;
   motor_lf = 0;
void left()
   motor_rg = 1;
   motor_lf = 0;
   motor_fwd = 0;
   motor_rvs = 1;
void right()
   motor_rg = 0;
   motor_lf = 1;
   motor_fwd = 1;
   motor_rvs = 0;
wheresaly
Re: need help with skps configuration+pic16f628a
Postby robosang » Tue Mar 26, 2013 9:37 am
What is the problem? You need to state clearly else no one can help.
Postby wheresaly » Thu Apr 11, 2013 3:20 pm
sorry for the late reply.
the problem is the project cannot be build in MPLab.
but after consulting with my lecturer.
i found that im using high tech c compiler for pic18.
after that i changed to the high tech c compliler for pic10/12/16.
the project already build.
1st problem solved.
now im facing difficulties bcoz the program i wrote is not working.
there is no OUTPUT at the pic.
need help.
wheresaly
