Multifunction Mobile Robot Rev2
Postby dausvilla77 » Thu Nov 28, 2013 2:07 am
This robot is designed to detect black line color.
http://www.cytron.com.my/viewProduct.ph ... bot%20Rev2
Can anybody help me how can I edit the source code to make the robot can detect white line color instead of black line color.
Here is attached the source code.
//   Author            :CYTRON
//   Project            :PR23
//   Project description   :Simple line follow
//  Version          :v1.4
//   include
#include <pic.h>
//   configuration
__CONFIG ( 0x3F32 );
//   define
#define sw1         RE0
#define sw2         RE1
#define motor_ra   RC0
#define motor_rb   RC3
#define motor_la   RC4
#define motor_lb   RC5
#define s_left      RB0
#define s_mleft      RB1
#define s_mright   RB2
#define s_right      RB3
#define buzzer       RE2
#define   rs         RB7
#define   e         RB6
#define   lcd_data   PORTD
#define b_light     RB5
#define SPEEDL      CCPR1L
#define SPEEDR      CCPR2L
#define   CHANNEL0   0b10000001   // AN0 ( Ultrasonic )
#define   CHANNEL1   0b10001001   // AN1 ( Distance sensor )
//skps protocol
#define   p_select      0
#define p_joyl         1
#define p_joyr         2
#define p_start         3
#define p_up         4
#define p_right         5
#define p_down         6
#define p_left         7
#define   p_l2         8
#define   p_r2         9
#define p_l1         10
#define p_r1         11
#define p_triangle      12
#define p_circle      13
#define p_cross         14
#define   p_square      15
#define p_joy_lx      16
#define   p_joy_ly      17
#define p_joy_rx      18
#define p_joy_ry      19
#define p_joy_lu      20
#define p_joy_ld      21
#define p_joy_ll      22
#define p_joy_lr      23
#define p_joy_ru      24
#define p_joy_rd      25
#define p_joy_rl      26
#define p_joy_rr      27
#define   p_con_status   28
#define p_motor1      29
#define p_motor2      30
#define RX_PIN       RC7
#define TX_PIN       RA2
#define BOT_ADD      100
//   global variable
unsigned char data[6] = {0};
const unsigned char line [] = {"1.LINE FOLLOW"};
const unsigned char US[] = {"2.Ultrasonic"};
const unsigned char AS[] = {"3.Analog Sensor"};
const unsigned char XB[] = {"4.SKXBEE"};
const unsigned char SKPS[] = {"5.SKPS"};
const unsigned char *mode [5] = {&line[0],&US[0],&AS[0],&XB[0],&SKPS[0]};
unsigned int result;
unsigned int To=0,T=0,TH=0;
unsigned char REC;
unsigned char i=0,raw;
unsigned int us_value (unsigned char mode);
//   function prototype
void init(void);
void e_pulse(void);
void lcd_clr(void);
void line_follow(void);
void ultrasonic(void);
void wireless_xbee(void);
void analog_sen(void);
void SKPS_PScon(void);
void forward(void);
void stop (void);
void backward (void);
void reverse (void);
void left(void);
void right(void);
unsigned char uart_rec(void);
unsigned char skps(unsigned char data);
void skps_vibrate(unsigned char motor, unsigned char value);
void read_adc(char config);
//   interrupt prototype
   if (TMR0IF)                        // TMR0 is overflow
      TMR0IF = 0;                   // clear flag bit
      To +=0x100;                     // count number of TMR0 overflow ( make it to 16bit TMR)
   if(RBIF)                        // there is change bit on RB4-RB7
      RBIF = 0;                     //                                     ____
      if (RB4)                     // Rb4 is 1 mean is rising form 0  __|
         TMR0 = 0;                  // clear all counter involved, start new count for period of RB4 high
         To = 0;
                                 //                           ___
      else TH = TMR0 + To;            // RB4 is 0 mean is falling form 1       |_____  // save TH, RB4 high period
   if(RCIF)
      RCIF = 0;                     // clear flag bit
      if (RCREG == 'R') data[i=0]= RCREG;            // check if start byte 'R' is met
      else if (RCREG == 100) data[i=0]= RCREG;      // check if start byte 'd'(decimal 100) is met
      if ((data[0] == 'R'))data [i++] = RCREG;      // save the data in data array
      if (i>4) i = 4;                           // if the data array reached max, set the index to 4
//   main function
void main(void)
   unsigned char m=0,i =0;
   delay(20000);
   init();                                 // initiate cnfiguration and initial condition
   buzzer = 1;                              // inditcate the circuit is on with beep
   lcd_clr();                              // clear the LCD screen
   send_string("Select mode");                  // display "select mode"
   lcd_goto(20);                           // move to 2nd line
   send_string(mode[m]);                     // display string according to the mode
   buzzer = 0;                              // stop beep
   while(1)                              // loop
      if( !sw1)                           // if button SW1 is pressed
         while(!sw1);                     // wait ubtul button is released
         m++;
         if ( m > 4) m = 0;                  // if mode is added more than three, set to zero
         lcd_goto(20);                     // start display at 20
         send_string(mode[m]);               // display string depend on mode
         send_string("       ");               // space to overwrite long words
      if (!sw2)                           // if button SW2is pressed
         while(!sw2);                     // wait until button is released
         switch(m)                        // check what is the current mode, execute the mode
            case 0 :   line_follow();         // mode 1 : line follow
                     break;
            case 1 :   ultrasonic();         // mode 2 : ultrasonic mode
                     break;
            case 2 :   analog_sen();         // mode 3 : analog sensor mode
                     break;
            case 3 :   wireless_xbee();      // mode 4 : wireless xbee mode
                     break;
            case 4 :    SKPS_PScon();         // mode 5 : PS2 Controller Mode
                     break;
            default :   ;
// Initailization
// Description : Initialize the microcontroller
void init()
   // ADC configuration
   ADCON1 = 0b10000100;            //set RA0 and RA1 as Analog Input, left justified
   // setup for capture pwm
   RBIE = 1;                     // enable interrupt on change of port B
   // motor PWM configuration
   PR2 = 255;                  // set period register
   T2CON =     0b00000100;         //
   CCP1CON =   0b00001100;         // config for RC1 to generate PWM   ( for more detail refer datasheet section 'capture/compare/pwm')
   CCP2CON =   0b00001100;         // config for RC2 to generate PWM
   // Tris configuration (input or output)
   TRISA = 0b00000011;            //set RA0 and RA2 pin as input,other as output
   TRISB = 0b00011111;            //set RB0-RB4 pin as input, other as output
   TRISC = 0b10000000;            //set PORTC pin as output
   TRISD = 0b00000000;            //set all PORTD pin as output
   TRISE = 0b00000011;
   // TMR 0 configuation
   T0CS = 0;
   PSA = 0;
   PS2 = 1;                  // prescale 1:32
   PS1 = 1;                  //
   PS0 = 1;                  //
   TMR0IE = 1;                  // TMR0 Interrupt
   TMR0 = 0;
   //setup UART
   SPBRG = 0x81;                  //set baud rate to 9600 for 20Mhz
   BRGH = 1;                     //baud rate high speed option
   TXEN = 1;                     //enable transmission
   TX9 = 0;
   CREN = 1;                     //enable reception
   SPEN = 1;                     //enable serial port
   RX9 = 0;
   RCIE = 1;                     //enable interrupt on eachdata received
   // enable all unmasked interrupt
   GIE = 1;
   PEIE = 1;
   // LCD configuration
   send_config(0b00000001);      //clear display at lcd
   send_config(0b00000010);      //Lcd Return to home
   send_config(0b00000110);      //entry mode-cursor increase 1
   send_config(0b00001100);      //diplay on, cursor off and cursor blink off
   send_config(0b00111000);      //function
   TX_PIN = 1;
   b_light = 0;
   buzzer = 0;
   stop();
// Mode subroutine
// Mode 1 : line follow subroutine
// Description: Program for the robot to follow line
// For more detail about line follow concept please refer PR5
void line_follow()
   unsigned char memory;
   lcd_clr();                        // clear lcd screen
   send_string("Position");            // display "position" string
      if ((s_left==1)&&(s_mleft==0)&&(s_mright==0)&&(s_right==0))              // if only sensor left detected black line
      {   forward();                                                // motor forward
         SPEEDL = 0;                                                // left motor speed is 0
         SPEEDR = 255;                                             // right motor speed is 255(full speed)
         memory = PORTB&0b00001111;                                    // save current sensor position
         lcd_goto(20);                                             // lcd go to 2nd line 1st character
         send_string ("right  ");                                    // display "right"mean the robot's position is on the right side of the line
      else if ((s_left==1)&&(s_mleft==1)&&(s_mright==0)&&(s_right==0))         // if only sensor left detected black line
         SPEEDL = 180;                                             // left motor speed is 180
         lcd_goto(20);
         send_string ("m_right2");
      else if ((s_left==0)&&(s_mleft==1)&&(s_mright==0)&&(s_right==0))         // if only sensor middle left detected black line
         SPEEDL = 200;                                             // left motor speed is 200
         lcd_goto(20);
         send_string ("m_right1  ");
      else if ((s_left==1)&&(s_mleft==1)&&(s_mright==1)&&(s_right==0))         // if sensor middle left and sensor left detected black line
         lcd_goto(20);
      else if ((s_left==0)&&(s_mleft==1)&&(s_mright==1)&&(s_right==0))         // if sensor middle left and sensor middle right detected black line
         SPEEDL = 255;                                             // left motor speed is 255(full speed)
         lcd_goto(20);
         send_string ("middle ");
      else if ((s_left==0)&&(s_mleft==0)&&(s_mright==1)&&(s_right==0))         // if only sensor middle right detected black line
         SPEEDR = 200;                                             // right motor speed is 200
         lcd_goto(20);
         send_string ("m_left1   ");
      else if ((s_left==0)&&(s_mleft==1)&&(s_mright==1)&&(s_right==1))         // if sensor middle left, sensor middle right and sensor right detected black line
         lcd_goto(20);
      else if ((s_left==0)&&(s_mleft==0)&&(s_mright==1)&&(s_right==1))         // if sensor right and sensor middle right detected black line
         SPEEDR = 180;                                             // right motor speed is 180
         lcd_goto(20);
         send_string ("m_left2 ");
      else if ((s_left==0)&&(s_mleft==0)&&(s_mright==0)&&(s_right==1))         // if only sensor right detected black line
         SPEEDR = 0;                                                // right motor speed is 0
         lcd_goto(20);
         send_string ("left   ");
      else if ((s_left==0)&&(s_mleft==0)&&(s_mright==0)&&(s_right==0))         // if all sensor coult not detected black line
         if ((memory == 0b00000001)||(memory == 0b00000011)||(memory == 0b0000010)||(memory == 0b0000111))
         else if ((memory == 0b00001000)||(memory == 0b0000100)||(memory == 0b00001100)||(memory == 0b0001110))
      else if ((s_left==1)&&(s_mleft==1)&&(s_mright==1)&&(s_right==1))         // if all sensor detected black line
// Mode 2 : Ultrasonic
// Description: Maintain distance measure using ultrasonic between obsacle and robot
// Can choose data acquiring methode between ADC, PWM and UART
   int distance;                                                // variable for distance measuring
   char n=1;                                                   // index for indicat mode
   send_string("Measure mode");                                    // display string
   lcd_goto(20);                                                // lcd goto 2nd line
   send_string("ADC");                                             // Display string "ADC"
   while(1)                                                   // loop forever unless sw2 is pressed
      if( !sw1)                                                // if button s1 is pressed
         while(!sw1);                                          // wait until sw1 is release
         n++;                                                // increment n
         lcd_goto(20);                                          // goto 2nd line
         switch (n)                                             // check current value of n
            case 2 :    send_string("PWM");
                     break;                                    // break out from switch
            case 3 :    send_string("UART");
            default:     send_string("ADC");                           // if not 2 or 3, set ti back to 1 and display "ADC"
                     n =1;
      if (!sw2)                                                // if button sw2 is pressed
         while(!sw2);                                          // wait until sw2 is release
         break;                                                // break out form looping
   lcd_clr();                                                   // clear the lcd
   send_string("Distance");                                       // display string "Distance"
      distance = us_value(n);                                       // disance variable are equal to value return from subroutine us_value
      dis_num(distance);                                          // display the value of distance
       if (distance> 40)                                          // check if distance more than 40
         forward();                                             // then forward with full speed
         SPEEDL = 255;
         SPEEDR = 255;
         buzzer = 0;
      else if (distance> 30)                                       // check if distance more than 40
         forward();                                             // forward with medium speed
         SPEEDL = 230;
         SPEEDR = 230;
         buzzer = 0;
      else if( distance >20)                                       // check if distance more than 40
         stop();                                                // then stop
         buzzer = 0;
      else                                                    // else, distance less than 20
         backward();                                             // then backward with medium speed and on the buzzer
         SPEEDL = 230;
         SPEEDR = 230;
         buzzer = 1;
// Mode 3 : Analog Distance Sensor
// Description : Maintain distance between robot and obstacle
      read_adc(CHANNEL1);                                       // read adc channel 1 ( analog distance sensor input)
      distance = result;                                       // assign distance as the result oft he reading
      dis_num(result);                                       // display the value
      if (distance< 200)                                       // check if distance less than 200
         backward();                                          // backward with full speed
         SPEEDL = 255;
         SPEEDR = 255;
         buzzer = 0;
      else if (distance< 250)                                    // check if distance less than 250
         backward();                                          // backward with medium speed
         SPEEDL = 230;
         SPEEDR = 230;
         buzzer = 0;
      else if( distance < 300)                                 // check if distance less than 300
         stop();                                             // stop
         buzzer = 0;
      else                                                 // else, distance more than 300
         forward();                                          //forward with medium speed and on buzzer
         SPEEDL = 230;
         SPEEDR = 230;
         buzzer = 1;
//Mode 4 :  Xbee
// Description : Control the robot using UART ( XBEE or an UART wireless module.
void wireless_xbee (void)
   while(1)                                                // looping forever
      lcd_goto (0);
      if (data[0] == 100)                                       // check if UART start byte is met
         send_string("  XBEE CONTROL  ");                        // display string
         SPEEDL = 200;                                       // set the motor speed
         SPEEDR = 200;
            lcd_goto(20);
            if (RCREG == '8')                                    // if character '8' is detected, the robot move forward
               forward();
               send_string("FORWARD        ");
            else if (RCREG == '2')                                 // if character '2' is detected, the robot move backward
               backward();
               send_string("BACKWARD        ");
            else if (RCREG == '6')                                 // if character '6' is detected, the robot turn right
               right();
               send_string("TURN RIGHT      ");
            else if (RCREG == '4')                                 // if character '4' is detected, the robot turn left
               left();
               send_string("TURN LEFT       ");
            else if (RCREG == '5')                                  // if character '5' is detected, then stop the robot
               stop();
               send_string("INVALID COMMAND  ");
            else                                              // else then stop the robot
               stop();
      else    send_string("COMMAND");
// Mode 5: SKPS
// Description: Control the robot using PS Controller
void SKPS_PScon()
   unsigned char up_v, down_v, left_v, right_v;
   //Disabled Intterupt
   RCIE = 0;
   GIE = 0;
   PEIE = 0;
   TMR0IE = 0;
   stop();         //stop all motor
   lcd_clr();
   lcd_goto(0);
   send_string("Controlling PR23");
   lcd_goto(20);
   send_string("   Using SKPS");
      //test button for horn
      if(skps(p_l1)==0)buzzer=1;         //if button L1 pressed, beep the buzzer
      else buzzer=0;
      //read joy stick value process
      up_v=skps(p_joy_ru);
      down_v=skps(p_joy_rd);
      left_v=skps(p_joy_ll);
      right_v=skps(p_joy_lr);
      //button control for mobilility
      if(skps(p_up)==0)               //check "up" button
         forward();                  //move forward
         SPEEDL=230;
         SPEEDR=230;
      else if(skps(p_down)==0)         //check "down" button
         backward();                  //move backward
         SPEEDL=230;
         SPEEDR=230;
      else if(skps(p_left)==0)         //check "left" button
         left();                     //rotate left
         SPEEDL=230;
         SPEEDR=230;
      else if(skps(p_right)==0)         //check "right" button
         right();                  //rotate right
         SPEEDL=230;
         SPEEDR=230;
      //analog control for mobility
      else if(up_v>0)
         forward();
         if(left_v>0)
            if(up_v>left_v)SPEEDL=up_v-left_v+140;
            else SPEEDL=140;
            SPEEDR=up_v+140;
         else if(right_v>0)
            if(up_v>right_v)SPEEDR=up_v-right_v+140;
            else SPEEDR=140;
            SPEEDL=up_v+140;
         else
            SPEEDL=up_v+140;
            SPEEDR=up_v+140;
      else if(down_v>0)
         backward();
         if(left_v>0)
            if(down_v>left_v)SPEEDR=down_v-left_v+140;
            else SPEEDR=140;
            SPEEDL=down_v+140;
         else if(right_v>0)
            if(down_v>right_v)SPEEDL=down_v-right_v+140;
            else SPEEDL=140;
            SPEEDR=down_v+140;
         else
            SPEEDL=down_v+140;
            SPEEDR=down_v+140;
      else if(left_v>0)
         left();
         SPEEDL=left_v+120;
         SPEEDR=left_v+120;
      else if(right_v>0)
         right();
         SPEEDL=right_v+120;
         SPEEDR=right_v+120;
      else
         stop();
         SPEEDL=255;
         SPEEDR=255;
// Ultrasonic value
// Description : Retrive data from Ultrsonic. Can choose methode between ADC, PWM and UART
// Parameter : mode      1) using analog
//                  2) using pwm
//                  3) using uart
unsigned int us_value (unsigned char mode)                                 // subroutine for ultrasonic measurement
   unsigned int value;
   switch (mode)                                                   // retrive value of measured distane based on the methode selected
      case 1:   read_adc(CHANNEL0);
            value = result;                                          // max vslue 2.55v = 2.55/5 *1024 - 1 =  522, resolution = 10mV/ inch, 10m/5*1024 =~ 2
            break;
      case 2:   value = TH;                                             // each value = 256*4/20mhz = 51.2us, i inch = 147us
            break;                                                // can change using smaller timer prescale, but resulation fixed 147us / inch
      case 3:   if ( data [0]=='R')   value = (data[1] - 0x30)*100+ (data[2] - 0x30)*10+ (data[3] - 0x30); // 1 = 1 inch
            else
               lcd_goto(20);                                       // if stater byte is not 'R', Display 'not connected'
               send_string("not connected");
               while(1);                                          // loop forever
      default: ;
   return value;
// read adc
// Description: subroutine for converting analog value to digital with average 200 samples
// Parameter : config  ( select the channel )
   unsigned short i;
   unsigned long result_temp=0;
   ADCON0 = config;
   delay(10000);               // delay after changing configuration
   for(i=200;i>0;i-=1)            //looping 200 times for getting average value
      ADGO = 1;               //ADGO is the bit 2 of the ADCON0 register
      while(ADGO==1);            //ADC start, ADGO=0 after finish ADC progress
      result=ADRESH;
      result=result<<8;         //shift to left for 8 bit
      result=result|ADRESL;      //10 bit result from ADC
      result_temp+=result;
   result = result_temp/200;      //getting average value
   ADON = 0;                  //adc module is shut off
// Motor control function
// Description : subroutine to set the robot moving direction
void forward ()
   motor_ra = 0;
   motor_rb = 1;
   motor_la = 0;
   motor_lb = 1;
void backward ()
   motor_ra = 1;
   motor_rb = 0;
   motor_la = 1;
   motor_lb = 0;
void left()
   motor_la = 1;
   motor_lb = 0;
   motor_ra = 0;
   motor_rb = 1;
void right()
   motor_la = 0;
   motor_lb = 1;
   motor_ra = 1;
   motor_rb = 0;
void stop()
   motor_la = 1;
   motor_lb = 1;
   motor_ra = 1;
   motor_rb = 1;
//   LCD   functions
void delay(unsigned long data)               //delay function, the delay time
   for( ;data>0;data-=1);                  //depend on the given value
void send_config(unsigned char data)         //send lcd configuration
   rs=0;                              //set lcd to config mode
   lcd_data=data;                        //lcd data port = data
   delay(400);
   e_pulse();                           //pulse e to confirm the data
void send_char(unsigned char data)            //send lcd character
   rs=1;                              //set lcd to display mode
   delay(400);
void e_pulse(void)                        //pulse e to confirm the data
   e=1;
   delay(300);
   e=0;
   delay(300);
void lcd_goto(unsigned char data)            //set the location of the lcd cursor
    if(data<16)                           //if the given value is (0-15) the
   {                                 //cursor will be at the upper line
       send_config(0x80+data);
   else                              //if the given value is (20-35) the
   {                                 //cursor will be at the lower line
       data=data-20;                     //location of the lcd cursor(2X16):
      send_config(0xc0+data);               // -----------------------------------------------------
   }                                 // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
}                                    // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
void lcd_clr(void)                        //clear the lcd
    send_config(0x01);
   delay(350);
void send_string(const char *s)             //send a string to display in the lcd
   unsigned char hundred_thousand;
   unsigned char ten_thousand;
   unsigned char thousand;
   unsigned char hundred;
   unsigned char tenth;
   hundred_thousand = data/100000;                  // devide to get the numerator       eg: 5234/1000 = 5
   data = data % 100000;                        // modulas to get the remainder    eg: 5234%1000 = 234
   ten_thousand = data/10000;
   data = data % 10000;
   thousand = data / 1000;
   data = data % 1000;
   hundred = data / 100;
   data = data % 100;
   tenth = data / 10;
   data = data % 10;
   send_char(hundred_thousand + 0x30);               //0x30 added to become ASCII code char '0' to '9'
   send_char(ten_thousand + 0x30);
   send_char(thousand + 0x30);
   send_char(hundred + 0x30);
   send_char(tenth + 0x30);
   send_char(data + 0x30);
// uart function
void uart_send(unsigned char data)   //function to send out a byte via uart
   while(TXIF==0);               //wait for previous data to finish send out
   TXREG=data;                  //send new data
unsigned char uart_rec(void)      //function to wait for a byte receive from uart
   unsigned char temp;
   while(RCIF==0);               //wait for data to received
   temp=RCREG;
   return temp;               //return the received data
// skps function
unsigned char skps(unsigned char data)         //function to read button and joystick
{                                    //information on ps controller
   uart_send(data);
   return uart_rec();
{                                    //function to control the vibrator motor
   uart_send(motor);                     //on ps controller
   uart_send(value);
dausvilla77
Re: Multifunction Mobile Robot Rev2
Postby ober » Thu Nov 28, 2013 11:46 am
Basically, you will need to change this function:
void line_follow()
         lcd_goto(20);
         lcd_goto(20);
         lcd_goto(20);
         lcd_goto(20);
         lcd_goto(20);
         lcd_goto(20);
         lcd_goto(20);
         lcd_goto(20);
Make the logic of all sensor (s_left, s_mleft, s_mright) into inverse, if it is logic 0, change to 1 and vise versa. Please change all the condition, Not to forget the memory too.
Please do study and understand the code, you need to understand the concept to be able to modify and make use of it.
Postby dausvilla77 » Thu Nov 28, 2013 2:04 pm
Thank you very much, Ober..I has edited the code as you said and it can be build. Can you check, is it like this ?
void line_follow()
      if ((s_left==0)&&(s_mleft==1)&&(s_mright==1)&&(s_right==1))              // if only sensor left detected white line
         memory = PORTB&0b11110000;                                    // save current sensor position
      else if ((s_left==0)&&(s_mleft==0)&&(s_mright==1)&&(s_right==1))         // if only sensor left detected white line
         lcd_goto(20);
      else if ((s_left==1)&&(s_mleft==0)&&(s_mright==1)&&(s_right==1))         // if only sensor middle left detected white line
         lcd_goto(20);
      else if ((s_left==0)&&(s_mleft==0)&&(s_mright==0)&&(s_right==1))         // if sensor middle left and sensor left detected white line
         lcd_goto(20);
      else if ((s_left==1)&&(s_mleft==0)&&(s_mright==0)&&(s_right==1))         // if sensor middle left and sensor middle right detected white line
         lcd_goto(20);
      else if ((s_left==1)&&(s_mleft==1)&&(s_mright==0)&&(s_right==1))         // if only sensor middle right detected white line
         lcd_goto(20);
      else if ((s_left==1)&&(s_mleft==0)&&(s_mright==0)&&(s_right==0))         // if sensor middle left, sensor middle right and sensor right detected white line
         lcd_goto(20);
      else if ((s_left==1)&&(s_mleft==1)&&(s_mright==0)&&(s_right==0))         // if sensor right and sensor middle right detected white line
         lcd_goto(20);
      else if ((s_left==1)&&(s_mleft==1)&&(s_mright==1)&&(s_right==0))         // if only sensor right detected white line
         lcd_goto(20);
      else if ((s_left==1)&&(s_mleft==1)&&(s_mright==1)&&(s_right==1))         // if all sensor coult not detected white line
         if ((memory == 0b10000000)||(memory == 0b11111100)||(memory == 0b1111101)||(memory == 0b1111000))
         else if ((memory == 0b11110111)||(memory == 0b1111011)||(memory == 0b11110011)||(memory == 0b1110001))
      else if ((s_left==0&&(s_mleft==0&&(s_mright==0&&(s_right==0)         // if all sensor detected white line
dausvilla77
