PR8
Re: PR8
Postby bahirah87 » Sun Nov 07, 2010 1:36 am
can u explain about the use of button 1 and 2...
bahirah87
Re: PR8
Postby himura_ryuu » Sun Nov 07, 2010 12:31 pm
Problem solved.
Topic Closed.
:D
"Q.E.D
Shoumei Shouryou"
himura_ryuu
Re: PR8
Postby optitech » Fri Nov 11, 2011 1:59 pm
Hello,
Its mean that we only need to connect 1 wire only?
RC7(Pic) to Rx(UART) only?
How about the Tx? Not need?
How to connect the ground of the UART?
optitech
Re: PR8
Postby ober » Sat Nov 12, 2011 7:28 am
optitech WROTE:Hello,
Are you referring to PR8? You should refer to its schematic.
For RFID reader, it will only transmit data to host (computer or microcontroller) as it can only read RFID tag's ID. So transmitting data to this type of RFID reader is meaningless. GND pin is a must for voltage reference.
UART Problem
Postby optitech » Fri Nov 18, 2011 1:56 pm
I think i has succeeded connecting the wire needed.
i also build a VB program to connect to serial port(using UART UC00B)
But the problem is, the character sent to Hyperterminal & my VB program showing like below:
For the LCD, the character displayed perfectly.
im using the code provided by cytron(pr8).
UPDATE:
My problem solve, using another vb program.
optitech
Re: PR8
Postby ober » Tue Nov 22, 2011 7:20 pm
Good to hear that.
Share some photo of your project if you don mind.
