diy-14 motion sensor
Postby kitchaiz » Mon Sep 28, 2009 5:06 pm
hi!
wanna ask about if i using 84a in this project,is it the pir sensor works?
i refer to the 84a datasheet, ithink there don have any pin for analog sensor input..
i need some clue..
kitchaiz
Re: diy-14 motion sensor
Postby sich » Mon Sep 28, 2009 6:28 pm
Yes, It'll work. You no need an analog pin to sense the PIR sensor's signal. It gives discrete (High/Low) signal. Please refer to the datasheet:
http://www.cytron.com.my/datasheet/sensor/PIR_UserManualv1.pdf
Postby kitchaiz » Sun Oct 04, 2009 2:12 am
hi again,
//Scanning mode
case 2:
temp2+=1;
if(temp2<2500) led=1; //LED blink
else if(temp2<200000) led=0;
else temp2=0;
break;
wanna ask about value for temp2<2500 and temp2<20000, those value if convert to second and how is it? is it depends 876A 20 Mhz...
if i using 84a to setting led blink for 15secs and how shoud i value for temp2?? hope will see ur reply soon.
kitchaiz
Postby sich » Mon Oct 05, 2009 12:00 pm
If you are using assembly language, you may do some calculation from the crystal value you choose to get the time for each instruction cycle and then obtain the number of loops you need to create the delay period. But I think this approach is not so suitable for C language. It's hard to get the exact value.
There's an easy way to do it. You can use the tool provided by MPLAB IDE. Select Debugger > Select Tool > 4 MPLAB SIM. Now a debug toolbar appears. Then select Debugger > StopWatch and a Stopwatch window pops up.
After setting the breakpoints, the stopwatch will calculate the time between two breakpoints for you when you run the debugger.
Postby xfreelifex » Sun Apr 04, 2010 1:04 am
how to attach this project with my webcam so i can record any motion detect??
xfreelifex
Postby sich » Mon Apr 05, 2010 11:35 am
xfreelifex WROTE:how to attach this project with my webcam so i can record any motion detect??
A webcam needs computer for interfacing.
Basically you'll need to connect this PR project set to your computer (usually is using UART and you'll need to modify the source code), then write a program to run on your computer to read the UART data from PR project set and command the webcam to snap photo when motion is detected.
Anyway, there're many ways to connect the sensor to computer. Another way would be using the PIR sensor (without PR project board) and a USB to UART converter (UC00A). In this case, no embedded programming is needed but you need to detect the signal from the sensor through UC00A. A sample of using UC00A with computer program for this purpose is given here: http://blog.cytron.com.my/?p=1102 Then, you need to find a way to communicate with your webcam and ask it to take photo.
Postby sich » Mon Apr 05, 2010 11:47 am
Some other alternatives:
1. Hack a digital camera and connect the snap button to this PR project with some additional components. No computer is needed and this will be the simplest way that delivers the same result.
2. Using CMUcam2 which is designed for interfacing with embedded system via UART. It has image processing capabilities and is too powerful for your application.
