New QuestionIt the PR23 Source Code, the sensor is read/used via mode
So, how can we modified the mode of sensor so that, say the analog sensor and ultrasonic to be used on the same time???
The ultrasonic is used as center sensor and another two sets of analog sensor is used on the left and right side.
void ultrasonic(void)
int distance;
n=1;
if (distance>40)
void analog_sen(void)
int distance;
if (distance>200)
"In the ultrasonic mode, the if function written (distance>40)
This 40 is measured in what unit???
In the analog_sensor mode, the if function written (distance>200)
This 200 is measured in what unit???
Huhuhu~ Again, number makes me confused~
In LCD program,
lcd_goto(20) //send string to second line
"I believe it says clearly that this LCD command is used to display on the second line of the LCD Display. However, do this number 20 is fixed??? I mean, can i change the number to another number but having the same function of sending data to second line display???
Sorry for questioning so much~
