by temporary40 » Thu Jan 06, 2011 11:04 pm
To create header, you will need to create a H file and another corresponding C file.
1) From your main C file (where you put the main() function), include the H file.
For example
____________________________________________
|#include <function.h>
|int main()
| //your main program here...
2) Then in the function.h, you will need to have your function prototype. Remember to add the preprocessor (#ifndef, #define, #endif) so your compiler will compile it once only.
For example...
|#ifndef FUNCTION
|#define FUNCTION
|int myfunc();
|int myfunc2();
|int myfunc3();
|#endif
3) Then, in the corresponding c file (function.c), include the the function.h and write the subroutine function (function definition).
|int myfunc()
| //code here
|int myfunc2()
| //code here
|int myfunc3()
| //code here
4) You are allowed to create global variables in the function.c file
|int value, value1 = 100, value2 = 200;
5) But if you want the variables to be accessed in other file (for example the main function), you need to 'extern' the variables in the function.h file
|extern int value, value1, value2
This is basically sums it up...
