how to show the time of the real time clock by using LCD?
Postby IsaacChuah90 » Sat Jun 11, 2011 2:21 am
Now i m doing an alarm clock.I m having a problem is how can I show the time of the real time clock chip on my LCD screen display.Thanks for the help.
IsaacChuah90
Re: how to show the time of the real time clock by using LCD
Postby shahrul » Sat Jun 11, 2011 9:34 am
You can see example I2C of RTC or example set time and date. Example project with RTC is Door Access.
Postby robosang » Sat Jun 11, 2011 4:04 pm
You can also try Cytron's DIY project, I am sure they have plenty of examples in there. I think they have 1 which is interface with DS1307, RTC chip and do something like digital clock..
Postby IsaacChuah90 » Sat Jun 11, 2011 4:51 pm
ya.that cytron project is PR12 rite?so can i implement a motion sensor and buzzer to make it as a motion detected alarm clock?I'm using PIC16F877A.this microcontroller not much different wif PIC16F876A.
IsaacChuah90
Postby Brian Griffin » Sat Jun 11, 2011 9:43 pm
IsaacChuah90 WROTE:ya.that cytron project is PR12 rite?so can i implement a motion sensor and buzzer to make it as a motion detected alarm clock?I'm using PIC16F877A.this microcontroller not much different wif PIC16F876A.
Sure you can, write the additional routines of the motion sensor and buzzer into the microcontroller. :)
Postby IsaacChuah90 » Sat Jun 11, 2011 11:30 pm
Oh.Ok.I get it.So where can I get the sample code or example to do it?Because I m quite a freshman on this kind of field.try to do it. :D
IsaacChuah90
Postby shahrul » Sat Jun 11, 2011 11:49 pm
IsaacChuah90 WROTE:Oh.Ok.I get it.So where can I get the sample code or example to do it?Because I m quite a freshman on this kind of field.try to do it. :D
You can get the sample code RTC, sensor, buzzer but no code for specific project. No one will give specific project code for free.
Postby shiyan » Sun Jun 12, 2011 7:14 pm
Yup, Shahrul is right!
You can get, but you cannot modify if you don understand it. Integration is the basic thing to do, if even integration you need sample code.... then you will be learning nothing 8-)
shiyan
Postby IsaacChuah90 » Sun Jun 12, 2011 11:24 pm
Ok.I get it.Thanks!!! :D
IsaacChuah90
