I have read "Do it yourself" document of this IC & I observed that there 4 switches can be used & play 4 recordings each 15 seconds. My problem is "is it possible to use this IC to record & play 8 recordings each 6 or 7 seconds using 8 switches..............???
If can what are the changes that I should do to circuit.
here is the DIY project.
http://cytron.com.my/userpage.php?id=PR17
thank you
