autosleep rtc
autosleep rtc
Postby yasin » Tue Oct 16, 2012 3:19 pm
is it possible to apply autosleep function using rtc?
yasin
Re: autosleep rtc
Postby Idris » Tue Oct 16, 2012 5:16 pm
Which one you want to apply sleep mode? The microcontroller or RTC chip? If microcontroller it is possible, if RTC chip I'm not sure because RTC need always run to maintain time and date.
Re: autosleep rtc
Postby yonghui » Thu Oct 18, 2012 12:01 am
do u mean tat using rtc to sleep the device when time reach?
Re: autosleep rtc
Postby yasin » Wed Oct 31, 2012 8:08 pm
Idris WROTE:Which one you want to apply sleep mode? The microcontroller or RTC chip? If microcontroller it is possible, if RTC chip I'm not sure because RTC need always run to maintain time and date.
i want to apply the auto sleep on my project so that it will turn off when reach certain time...i need some idea bcos this is my 1st time uisng rtc.
yasin
Re: autosleep rtc
Postby yasin » Wed Oct 31, 2012 8:09 pm
yonghui WROTE:do u mean tat using rtc to sleep the device when time reach?
yup..is that possible?
yasin
Re: autosleep rtc
Postby zhenning » Wed Oct 31, 2012 8:40 pm
You can make the device continuously sleep and wakes up either when interrupted or the time has reached. Then do anything you want to do. After that sleep again and wait for the next interrupt. Its also possible vice versa. just call the sleep function or set the associated register.
zhenning
