LCD does not show up the characters
Postby mohdismiaswaly » Sat Sep 28, 2013 11:58 pm
Hello,
I am planning to display a string of characters using 16x2 LCD module.
Please see the photo below. I put the compiled code (hex file) into Proteus simulation. It does running normal.
But when I put the code inside my PIC18F4550 connected to all 16 pins of the LCD (TGK model bought from Cytron), there was just a block of black display appeared. I have check all the solder points, there are no short circuit between all 16 pins.
Simulation OK, but real hardware NOT OK.
How????
real hardware result
mohdismiaswaly
Re: LCD does not show up the characters
Postby mohdismiaswaly » Sat Sep 28, 2013 11:59 pm
Here is what I got from simulation in Proteus...
mohdismiaswaly
Postby mohdismiaswaly » Sun Sep 29, 2013 12:12 am
This is my code,
#include<htc.h>
#define   RS         RB4
#define   E            RB5
#define     lcd         PORTD
void init_lcd(void);
void MSDelay(unsigned int itime);
void lcdcmd(unsigned char value);
void lcddata(unsigned char data);
void e_pulse(void);
void delay(unsigned short i);
void send_char_end(unsigned char data);
void lcd_clr(void);
void main(void)
   while(1)
      TRISB=0;
      TRISD=0;
      send_config(0b00000001);      //clear display at lcd
      send_config(0b00000010);      //Lcd Return to home
      send_config(0b00000110);      //entry mode-cursor increase 1
      send_config(0b00001100);      //diplay on, cursor off and cursor blink off
      send_config(0b00111000);      //function set
      lcd_goto(0);               //cursor start from beginning
      send_char('T');
      send_char('O');
      send_char('T');
      send_char('A');
      send_char('L');
      send_char(' ');
      send_char('P');
      send_char('A');
      send_char('R');
      send_char('K');
      send_char('I');
      send_char('N');
      send_char('G');
      send_char('=');
      send_char('6');
      lcd_goto(20);               //cursor go to 2nd line of the LCD
      send_char('E');
      send_char('M');
      send_char('P');
      send_char('T');
      send_char('Y');
      send_char('=');
      send_char('?');
      send_char(' ');
      send_char('H');
      send_char('O');
      send_char('V');
      send_char('E');
      send_char('R');
      send_char('=');
      send_char_end('?');
//==================subroutine LCD setting ==========================
    RS=0;
   lcd=data;
   delay(500);
   e_pulse();
void e_pulse(void)
   E=1;
   delay(500);
   E=0;
   delay(500);
    RS=1;
   lcd=data;
   delay(4000);
   e_pulse();
    RS=1;
   lcd=data;
   delay(10000);
   e_pulse();
    if(data<16)
        send_config(0x80+data);
        else
    data=data-20;
   send_config(0xc0+data);
void lcd_clr(void)
    RS=0;
      send_config(0x01);
    delay(600);
//==================subroutine DELAY==========================
    for(;i>0;i--);
mohdismiaswaly
Postby robosang » Sun Sep 29, 2013 9:55 pm
I think the contrast is not adjusted correct, looking at 2 rows of black box on LCD.
Postby mohdismiaswaly » Thu Oct 03, 2013 12:18 am
You mean the connection of pin 15 and 16 on the lcd?
So I need to connect variable resistor in series to that pin?
mohdismiaswaly
Postby yonghui » Fri Oct 04, 2013 10:46 am
contrast is the vee pin. adjust the votalge value by changing resistor value.
