myzx WROTE:ABSF:
1.What you prefer d value for d Transistor the resistor if i'm using PNP Common Anode Transistor?
2.So if im using NPN Transistor so i must use Common Cathode(my output must 1 to enable digit)? While if i using PNP Transistor i should use Common Anode (my output must 0 to enable digit)? Is that right?
ABSF WROTE:May be putting resistors between PIC and 7-segment LEDs are just good practice. I would put them in unless my PCB is short of space. It all depends on indivisuals. I have notice some beginners never bother to put in resistors when blinking LEDs on the SK40C. But as PICs are getting cheaper each day, so who cares...![]()
As a hobbyist, I dont mind to burn a 16F628a or 12F629 but I wont risk the more expensive 40 pin or 68 pin PLCC PICs on this.
