apple737 WROTE:Does anyone know how to troubleshoot this? I havent got a reply for a long time.... =(
apple737 WROTE:Nope, i really need this PIC16F84 for my circuit board to work.
Sorry, i havent try...
in case anyone else has trouble with the pic16f84a and pickit 2 with low pin count demo board, here is how the pins match up.
all you need are those five from pickit 2 to the chip and you're ready to go
PICKIT 2 PINS PIC16F84A PINS
1 (13+V) 4 (mclr)
2 (5+v) 14 (Vdd)
3 (GROUND) 5 (Vss)
4 (PGD) 13 (RB7/PGD)
5 (PGC) 12 (RB6/PGC)
Does this mean i disconnect my PIC16F84 from the program board? Instead of program it in the programmable board, i connect it through breadboard and connect as above u have mention?
Btw, where is PGD and PGC? I cant find it on my PICKIT2 PINS.
Brian Griffin WROTE:apple737 WROTE:Nope, i really need this PIC16F84 for my circuit board to work.
1 (13+V) 4 (mclr)
2 (5+v) 14 (Vdd)
3 (GROUND) 5 (Vss)
According to the Low Pin Count demo board manual, PIC16F84(A) is not supported. You have to put it in the breadboard and connect them manually.
The PGD and PGC pins can be found on the Pickit2 pins. Please consult the manual for the programmer. It's located in the Pickit 2 software -> Help -> Pickit 2 User's Guide, page 9.
ober WROTE:We are using UIC00B to program PIC16F84A on SK18B without problem. But PIC16F84 does not seem to be supported by PICkit 2 nor MPLAB IDE. We do not have any PIC16F84 in our lab to verify this.
Sometime I see PIC16F84A in your post, but sometime is PIC16F84, which is the correct model you want to program?
