Help on PIC Simulator
Re: Help on PIC Simulator
Postby ober » Tue Aug 16, 2011 10:21 pm
We are using MPLAB IDE + HI-TECH C Compiler (for PIC16) or MPLAB C18 (for PIC18F).
You can refer to the tutorial of SK40C Getting Started
Postby TeoYX » Thu Aug 18, 2011 9:35 pm
I downloaded the source code of PR11 and do some simple modifications. However, i downloaded MPLAB but cannot debug the program. How to do the debug to check whether the program is correct or not? I haven't connect the PIC to my PC yet.
Please help. Thanks.
From,
Teo
TeoYX
Postby hyng » Fri Aug 19, 2011 9:44 am
If you build the code successfully, then you will no need to debug the code. Normally we will download the code into the PIC and see what is the result. If the code got error, double click on the error message and it will lead you to the error instruction and you can debug from there.
Below link content video to show how to create and build a PIC16F project in MPLab IDE.
http://tutorial.cytron.com.my/2011/08/18/how-to-create-a-project-in-mplab-ide/
Postby TeoYX » Fri Aug 19, 2011 9:18 pm
Is that work even i no connect the PIC to my pc?
Since i don't know whether my source code is correct or not, how do i debug to know the error if any?
Thanks for your teaching video, that's really helpful.
TeoYX
Postby TeoYX » Sat Aug 20, 2011 12:31 am
Can i use Microsoft Visual Studio to debug the PIC C-program?
TeoYX
Postby hyng » Sat Aug 20, 2011 11:13 am
TeoYX WROTE:Is that work even i no connect the PIC to my pc?
Yes, you can build your code even there is no PIC connected.
That's depending on your C programming skill, you have to learn. We provide many sample source code in C, you can learn from there. BTW, is your code really failed to build? Please don't be afraid to try your code on your circuit. At least it is my practice to test the code on my circuit. :lol: We always learning from mistake.
Postby TeoYX » Sat Aug 20, 2011 7:13 pm
Yes, i success just now. There is something wrong in the program. There shows ADGO is unidentified. I am using the PR11 Temperature Control LM35. This AFGO is the second bit in ADCON0. Do you know what is the problem?
Moreover, can i use Microsoft Visual Studio to do the debugging as well?
Please advice if anyone know. Thanks a lot.
TeoYX
Postby Brian Griffin » Sat Aug 20, 2011 10:42 pm
You cannot use Microsoft Visual Studio to debug. It is a different entity and PIC compilers has nothing got to do with a Visual Studio.
