16F877a to PC to Handphone
Re: 16F877a to PC to Handphone
Postby E11022 » Sun Dec 11, 2011 2:06 pm
i do not have GSM module and the serial cable DRS-11 for Sony Ericson T630 . Hence i need to use PC for the serial port, then to Handphone. yup, can Hyperterminal handle 2 com ports? this is another doubt.
if i only wanna display output to PC?
E11022
Postby ABSF » Mon Dec 12, 2011 6:56 am
E11022 WROTE:My PC got COM port, so i connected it like this:
Pin 2 (RS232) - Pin 14 (MAx232)
Pin 3 (RS232) - Pin 13 (MAX232)
Pin 12 (MAX 232) - Pin 25 (PIC)
Pin 13 (Max232 - Pin 26(PIC)
I think there's something wrong with the connections to MAX232. Please check it carefully refering to the datasheets of max232.
Postby E11022 » Mon Dec 12, 2011 9:05 am
Pin 13 (Max232 - Pin 26(PIC) PIN 11(max 232) - pin 26(PIC)
typo mistake.i manage to display data from PIC to hyperterminal,using putc('A'). but when the same command is add in my program code, the circuit is not working. I asked my friends about it. We debug the code together, cannot find any problem on the code.
#include "16f877a.h"
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7)
#define sensor PIN_A0
#define sw PIN_A1
#define buzzer PIN_C5
#define led PIN_C4
void main (void)
set_TRIS_C(0x00);
set_TRIS_A(0xff);
if((input(PIN_A0))&&(!input(PIN_A1)))
delay_ms(100);
puts("help!");
output_high(led);
output_high(buzzer);
else {}
else if ((!input(PIN_A0))&&(input(PIN_A1)))
output_low(led);
output_low(buzzer); }
else {
output_low(led);
E11022
