lcd view only black box in second row
Re: lcd view only black box in second row
Postby shahrul » Wed Feb 27, 2013 8:02 am
ax2030 WROTE:if i connect the pic direct to the lcd...which part of code that i need to adjust?? which pic pin needed to connect to the lcd...i'm only beginner in this..
This is normal people do, connect LCD pin direct to the PIC pin. You can refer here LCD or search in the google, many have done because this is common.
Postby yonghui » Wed Feb 27, 2013 9:52 am
i think tat black box is on the first row.
download sample code from cytron website also refer to tutorial by cytron:
http://tutorial.cytron.com.my/category/ ... arted/lcd/
go through the tutorial to know bout the lcd.
Postby ax2030 » Thu Feb 28, 2013 9:36 am
1 more thing i want to ask...what program should i use??
ax2030
Postby yonghui » Thu Feb 28, 2013 11:04 am
program?
Postby ax2030 » Thu Feb 28, 2013 6:01 pm
c programming sofwware..
ax2030
Postby robosang » Thu Feb 28, 2013 9:39 pm
You can use any C programming language that you familiar with. Are you using PIC? If so, you can HI-TECH, this is used by Cytron, most of their example code using HITECH Compiler. You can refer to their SK40C page, they have quite a lot of sample code at the bottom of page. You should try the PIC16F Sample Source Code.
Postby takao21203 » Mon Apr 08, 2013 3:30 pm
I have C code for 4bit mode on my web, with serial register.
The second row has a displacement for the address. The module may become thrown off if you write in other areas.
http://pic.hitechworld.org/pic-microcon ... expansion/
takao21203
