HOW TO USE ADC IN PIC18F
Re: HOW TO USE ADC IN PIC18F
Postby mohdismiaswaly » Thu Aug 22, 2013 4:07 pm
Hello,
How to write program for this:
"After that, start ADC conversion by set the bit GO on ADCON0<1>. Wait until conversion done and read ADRESH, ADRESL as the 10 bit result"
Mind to give the program code?
I just want to read the ADRESH and ADRESL register result.
Thanks
mohdismiaswaly
Postby ober » Mon Aug 26, 2013 9:39 am
mohdismiaswaly WROTE:How to write program for this:
ADCON0bits.GO = 1; //setting GO to start ADC conversion
while(ADCONbits.GO == 1) continue; //wait for ADC conversion to complete
// Read the ADRESH and ADRESL
Postby mohdismiaswaly » Thu Sep 12, 2013 11:53 pm
Hello everyone,
Below is the picture of my circuit connection. Humidity sensor is connected to pin RA0 (analog input) and all pin PORTD connected to 7 segment display (common anode) as output. What I want to do is to display ONLY the content of ADRESL registers to 7 segment display.
Note:
white wire=output from sensor connected to pin RA0
yellow wire=ground from sensor connected to ground to PIC
blue wire=output from PIC of PORTD pins (RD0-RD7)
red wire=Vdd (5V) from PIC to 7segment display
The problem is I write this code:
#include <htc.h>
main(void)
TRISC=0 ;
TRISD=0 ;
TRISAbits.TRISA0=0;
ADCON0 = 0x81 ;
ADCON1 = 0xcE ;
PORTA=0;
PORTC=0;
PORTD=0;
delay_ms(1) ;
ADCON0bits.GO = 1 ;
while(ADCON0bits.DONE == 1) ;
PORTD=ADRESL;
PORTC=ADRESH;
delay_ms(3000);
delay_ms(unsigned int x)
for(;x>0;x--);
T0CON=0x80; //Fosc 4MHz, Timer 0,16-bit mode, prescaler 1:2, use internal clock, increment on positive-edge
TMR0H=0x9E;
TMR0L=0X57;
T0CONbits.TMR0ON=1;
while(INTCONbits.TMR0IF==0);
T0CONbits.TMR0ON=0;
INTCONbits.TMR0IF=0;
Anything goes wrong? I am not sure the setting for ADCON0 and ADCON1. I am also not sure about the code I highlight in red colour above. Are they all correct?
circuit connection
mohdismiaswaly
Postby shahrul » Fri Sep 13, 2013 9:51 am
If you read adc on RA0, TRISA0 should set to 1 to become an input.
Then, I'm not checking the remaining code.
Postby mohdismiaswaly » Fri Sep 13, 2013 2:54 pm
So, I set TRISA0 to 1.
How about the code in red colour? Correct?
mohdismiaswaly
Postby mohdismiaswaly » Tue Sep 17, 2013 4:34 pm
Hello,
Anyone, please respond to the previous message as above.
Help needed.
:cry:
mohdismiaswaly
Postby sich » Tue Sep 17, 2013 6:29 pm
Actually what's the problem you encounter? And what have you achieved so far? What's the output of code? Please be more specific so we can assist you more effectively.
