pic16 WROTE:how to make the voltmeter in the diagram much more accurate....
i want to make it more precision,before upload its video..
So, you mean your voltmeter is working NOW?
What was the problems that you've found?
pic16 WROTE:I think he means add a better ADC before interface it with MCU. MCU's ADC has limited capabilities. You can get some standalone ADC IC
then how the circiut look like?
how to connect it into the circiut?
Brian Griffin WROTE:pic16 WROTE:I think he means add a better ADC before interface it with MCU. MCU's ADC has limited capabilities. You can get some standalone ADC IC
1.) You need an external ADC IC, like 12 to 16 bits. And of course, a good, regulated voltage reference inside too.
2.) You need some isolators between the test terminals and the ADC to prevent frying the whole system if you accidently put too high voltages/currents.
3.) And a modification of program code too.
pic16 WROTE:
1.) did cytron here sell any ADC IC?
2.) may giving me a sample circuit of this?
i no idea about the 3.)![]()
ABSF WROTE:pic16 WROTE:how to make the voltmeter in the diagram much more accurate....
Eh, do you have your voltmeter working first?
pic16 WROTE:sometime yes, sometime no
pic16 WROTE:are there other way to make the voltmeter more accurate, except using ADC IC?
ABSF WROTE:pic16 WROTE:are there other way to make the voltmeter more accurate, except using ADC IC?
If you just want to get an reasonably accurate voltmeter, the cheaper way is to do it without mcu. Take a look at the chip ICL7107 (LED) and ICL7106 (LCD) datasheet here
http://www.escol.com.my/Datasheets_specs/ICL7106-7.pdf
Most of the conventional multi-meters including my SANWA meter are based on this chip. The chip is only 8.50 each and I have 2 of them in my drawer but I haven't make use of them yet. Your project must have some problem in your construction as it shouldnt display blinking and weird numbers. Are your segments a-g connected accordingly to the schematics? As I see the pin numbers used are not in running orders like your first project.
