vick5821 WROTE:I just scared that the SK40C I got got some problems ma..haha
It might be SK40C problem but you can check it, as hyng suggested, you can try to load the sample code from their product page. I did use that before, the LEDs will blink alternately. Press switch will change the blinking rate.
I have once get a faulty SK40C, but Cytron call back to repair and send me a voucher
After that, it works fine! I have a few projects using SK40C with different PIC, 16F and 18F.
Brian Griffin WROTE:You are pretty a veteran here. Those times, all are started with a PIC16F84 and some electronic components, plus an expensive programmer. I started from a PICKit 2, so I'm considered very late.
Back in '99 when I got some electronic magazines cheap from the MPH clearence sale, I found ads for Basic Stamp, but didn't pestered my father to buy them. I should have started earlier, but hey, it's easier to do microcontrollers nowadays too.
The FreeRTOS is already there for the SKPIC32, with the latest version. I was about to make a mini-game out with the GLCD out of it but work's piling up on me, so didn't do anything on it.
In fact, there are RTOSes for PIC16 and PIC18F. One of the RTOS I got is successfully programmed and I manage to simulate it in Proteus. If I have a spare bit of time I would port Myke Predko's example of his RTOS "digital thermometer clock" into the SK40C. I will use MikroC and also MPLAB C18 to implement this, and prolly you will be seeing one more of this in the tutorial section.
No.... not veteran, just a busy body, you are moving faster. I have yet to touch 32-bit, you already playing with RTOS. Anyway, keep it going, thanks for the sharing.
You write tutorial to Cytron site? Which one is yours? Should have something to do with 32-bit, right? Since you are good in that
Keep it up man! Kudos to you!
