PIC receive/transmit data
Postby valo » Mon Oct 04, 2010 4:13 am
hi all..
im a super newbie in microcontroller..
consider i have a rs232 device to be connected to PIC. thats mean the data flow through UART. the also PIC connected to PC ,also via UART (serial port). i wanna use an LCD which its output based on the data that have been send back by PC. what are the steps?
another question, is it possible that if i store password in the PIC, the rs232 device will enabled only if i entered correct password?
valo
Re: PIC receive/transmit data
Postby ober » Mon Oct 04, 2010 9:52 am
valo WROTE:im a super newbie in microcontroller..
welcome to Cytron technical forum. Seem to me that you are not newbie from the questions you asked. Since you need to interface with 2 devices that require UART, to make your programming straight forward you need to choose microcontroller that come with 2 or more UART peripheral. Alternatively, you could refer to PR27 which uses software to create what we called virtual UART.
I would advice to start your project with simple target, try to display message on LCD and interface with your RS232 device, then to your computer.
Hope that helps.
Postby shahrul » Mon Oct 04, 2010 7:35 pm
Ober have answered the question.
valo WROTE:another question, is it possible that if i store password in the PIC, the rs232 device will enabled only if i entered correct password?
For this, yes you can store a password in the PIC EEPROM.
Postby robosang » Tue Oct 05, 2010 9:57 am
Ya :shock: Start with the simple target, then slowly move to advance project..... save you a lot of time and money. Learn a lot too.
Yup, shahrul is right, you can actually save the data in EEPROM, PIC16F877A has 256 bytes of internal EEPROM which be written and read during program execution. Hi-Tech C Compiler should come with the library.
Postby nicholaswsw » Sat Oct 16, 2010 4:31 am
I have an question to ask as well say i'm using the 315Mhz and 433Mhz RF module and i want to connect it to PIC 16F877A. In this case i have to use 2 Tx and Rx Pins, are there any solutions to this issue? I was thinking of Multiplexing but then which IC to use, or there are other solutions?
nicholaswsw
Postby ober » Sat Oct 16, 2010 9:52 am
nicholaswsw WROTE:I have an question to ask as well say i'm using the 315Mhz and 433Mhz RF module and i want to connect it to PIC 16F877A. In this case i have to use 2 Tx and Rx Pins, are there any solutions to this issue? I was thinking of Multiplexing but then which IC to use, or there are other solutions?
I don get you good? help me here.
Why you need 2 Tx and Rx pin?
Postby nicholaswsw » Mon Oct 18, 2010 3:52 am
I'm using a Barcode Scanner with a RS-232C connection and i want to connect it to my PIC. And i'm using Zigbee to communicate with the another PIC so 1 Tx,Rx pins for the Rs232 and another Tx,Rx pin for the Zigbee Module
nicholaswsw
Postby ober » Mon Oct 18, 2010 10:24 am
Now I get more confuse :lol: Previous post you are talking about RF module, now you talk about ZigBee....
Anyway from your description, you should need 2 Rx and 1 Tx. You can either find yourself a PIC that come with 2 UART engine or write a software UART as shown in one of Cytron DIY project, PR27
Postby nicholaswsw » Thu Oct 21, 2010 7:18 pm
I'm a newbie here... I just want to ask 16F877a it's a 8 bit microcontroller, and Zigbee uses 16 bit addressing. Can I connect the two of them together?
nicholaswsw
Postby yonghui » Thu Oct 21, 2010 7:40 pm
the 8bit microcontroller can be used to control the zigbee. no problem.
