PIC16F676 voltmeter
PIC16F676 voltmeter
Postby pic16 » Fri Jan 28, 2011 11:47 am
Hi, everyone... :P
i have a question again about how to set the oscillator issue in this PIC16f676,
i am try to collect the component now & try to build one of this :mrgreen:
May help me take a quick look of this circuit and etc, before i blindness follow it? :oops:
p/s: source code added at 1 Feb 2011
v.rar
(14.26 KiB) Downloaded 422 times
pic16
Re: PIC16F676 voltmeter
Postby ABSF » Fri Jan 28, 2011 8:09 pm
I do not have this PIC with me. My simulator doesn't support this PIC. The source code is not included in your project file.
May be the newer version of ISIS supports this chip. Mine is v6.1 SP1. What do other members think?
Postby ABSF » Fri Jan 28, 2011 8:19 pm
pic16 WROTE:http://electronics-diy.com/electronic_schematic.php?id=721
Hi, everyone... :P
This circuit doesn't use external crystal oscillator. It is config to use its internal 4 MHz osc. You should download the datasheet and study it first before you proceed with it.
The config bits should be:
Oscillator = Internal RC No clockout
WatchDog = off
Power up timer = on
Master clear disable = Internally enabled
config word = 3F84
Postby shiyan » Fri Jan 28, 2011 10:51 pm
Schematic seem to be fine. There is a adjustable voltage divider to allow higher voltage than 5V, not bad. Using PNP transistor to multiplex common anode 7-segments + a dot :0
As for the internal crystal, I am not sure because I do not have simulator to simulate the hex code, but it should be fine if you follow suggestion from allen. Looking forward to see the video!
shiyan
Postby pic16 » Sat Jan 29, 2011 1:23 am
ABSF WROTE:I do not have this PIC with me. My simulator doesn't support this PIC. The source code is not included in your project file.
source code....
main.rar
(1.13 KiB) Downloaded 411 times
pic16
Postby pic16 » Sat Jan 29, 2011 1:30 am
but when i try to burn HEX file it have
Hi, everyone... :P
WatchDog = off
Power up timer = on
Materclear enable = Internal
config word = 3F84
my PIC16F676 have just arrive... :P
it got so many configuration.. :shock:
could no have 3F84
pic16
Postby pic16 » Sat Jan 29, 2011 1:35 am
i put some picture to let you guys guide me... :oops:
other setting just enable and disable...
which setting i should set?
pic16
Postby pic16 » Sat Jan 29, 2011 1:40 am
shiyan WROTE:Schematic seem to be fine. There is a adjustable voltage divider to allow higher voltage than 5V, not bad. Using PNP transistor to multiplex common anode 7-segments + a dot :0
ha.. :lol:
only if success :oops: :oops:
but i still waitting for some componet...
pic16
Postby ABSF » Sat Jan 29, 2011 7:24 am
#include <16F676.h>
#device adc=10
#fuses INTRC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR
[color=#FF0000]INTRC_IO = internal RC osc and RA4 and RA5 used as IO
NOWDT = No Watch Dog Timer
PUT = ???
NOPROTECT = Code not protected
BROWNOUT = brownout is YES
NOMCLR = Disable Master Clear
[/color]
#use delay (clock=4000000) // 4MHz clock
[color=#FF0000] Internal clock is 4MHz[/color]
#rom  0x3ff={0x3444}
#byte PORTA = 0x05
#byte PORTC = 0x07
#byte TRISA = 0x85
#byte TRISC = 0x87
#define SPORTA PORTA
#define SPORTC PORTC
#define  TICKS_BETWEEN_INTERRUPTS      5000 //5000
#define  INTERRUPT_OVERHEAD            35
#define  TMR1RESET (0xFFFF-(TICKS_BETWEEN_INTERRUPTS-INTERRUPT_OVERHEAD))
[color=#FF0000]Timer 1 is used for the interrupt to generate clock ticks[/color]
const char SegCode[11] = {0x40,0x57,0x22,0x06,0x15,0x0C,0x08,0x56,0x00,0x04,0xFF};
[color=#FF0000]The digit patterns on 7-seg LED + blank[/color]
   //                       0    1    2    3    4    5    6    7    8    9
const char Column[3]   = {0x02,0x01,0x04};
static char Segment[3] = {0x7f,0x7f,0x7f};   [color=#FF0000]"888"?[/color]
static unsigned char ColCount=0x00;
void CPU_SETUP(void);
void Display(void);
void HTO7S(unsigned int32 Num);
byte i;
unsigned int32 result;
#INT_TIMER1
[color=#FF0000]Is this the interrupt routine?  V V Neat[/color]
void Timer1(void)
   set_timer1(TMR1RESET);
   Display();
void main()
   unsigned char i;
   CPU_SETUP();
   while(true)
      result=0;
      for (i=0;i<20;i++)
         set_adc_channel(3);
         delay_ms(1);
         result=result+read_adc();
         //result = 0x3fe;
       HTO7S(result/20);
      delay_ms(200);
void CPU_SETUP()
   setup_comparator(NC_NC_NC_NC);   // not use comparator module
   setup_adc_ports( sAN3 | VSS_VDD);
   setup_adc(ADC_CLOCK_DIV_64);
   TRISA=0b00011000;
   PORTA=0x27;
   TRISC=0b00000000;
   PORTC=0x37;
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_1);
   enable_interrupts(GLOBAL);  [color=#FF0000]GIE=1[/color]
   enable_interrupts(INT_TIMER1);   [color=#FF0000]TMR1IE=1[/color]
// Display routine
void Display()
   PORTA = 0b00100111;     // off all digits column and Segment G
   PORTC = 0b00111111;   // off segment a-f
   delay_cycles(2);
   if (ColCount>=3)
   ColCount=0;
   SPORTC = Segment[ColCount];
   SPORTA = ((Segment[ColCount] & 0b01000000)>>1) | (Column[ColCount]^0x07);
   ColCount++;
// Convet HEX 2 byte to 7-Segment code
   unsigned int32 res;
   Segment[0]=SegCode[30*Num/10230];
   if (Segment[0]==0x40)
   Segment[0]=0xFF;
   res = 30*Num%10230;
   Segment[1]=SegCode[10*res/10230];
   res=10*res%10230;
   Segment[2]=SegCode[10*res/10230];
Does the codes look like HTC? Very doubtful. But anyway, see my comments in red.
Looks like your PIC configuration is already defined in the code & Hex files.
Postby ABSF » Sat Jan 29, 2011 7:30 am
Oops, code doesnt support color, sorry.
#include <16F676.h>
#device adc=10
PUT = Power-up timer enabled
NOMCLR = Disable external Master Clear (Use internal MR)
#rom 0x3ff={0x3444}
#byte PORTA = 0x05
#byte PORTC = 0x07
#byte TRISA = 0x85
#byte TRISC = 0x87
const char Column[3] = {0x02,0x01,0x04}; column scan pattern 0010, 0001, 0100
static char Segment[3] = {0x7f,0x7f,0x7f}; "888"?
void Display(void);
void HTO7S(unsigned int32 Num); Hex to 7seg converter
byte i;
#INT_TIMER1
void Timer1(void)
Display();
void main()
unsigned char i;
CPU_SETUP();
while(true)
result=0;
for (i=0;i<20;i++)
set_adc_channel(3);
delay_ms(1);
//result = 0x3fe;
HTO7S(result/20);
delay_ms(200);
void CPU_SETUP()
setup_adc_ports( sAN3 | VSS_VDD); set up adc on RA4/AN3 for voltage input
TRISA=0b00011000;
PORTA=0x27;
TRISC=0b00000000;
PORTC=0x37;
enable_interrupts(GLOBAL); GIE=1
enable_interrupts(INT_TIMER1); TMR1IE=1
// Display routine
void Display()
delay_cycles(2);
if (ColCount>=3)
ColCount=0;
ColCount++;
unsigned int32 res;
Segment[0]=0xFF;
res = 30*Num%10230;
res=10*res%10230;
Quotes looks better.
