by ABSF » Fri Feb 25, 2011 6:25 am
I dont think it is advisable to do everything on the breadboard for this project. At least not for the power supply and motor part which consumes more power. You can see that the PCBs are stacked together to reduce size. If you were to use breadboards, how are you going to interconnect between 2 breadboards reliably and how are you going to troubleshoot if there is problem?
Breadboard is good for doing a trial testing of simple circuits but for such a complex project using 4 or 5 PCBs, it is better to stick with PCBs. Besides, are all the software codes given off freely for this project ? If not, do you have any experience in writing C codes for PIC?
Soldering is no big deal. There are temperature controlled soldering irons so you wont overheat the component that easily nowadays. So start practising soldering and I wish you best of luck in your w.c. forklift project.
