PIC18F uart baud rate problem
Postby jeffrey5337 » Thu Mar 03, 2011 9:13 pm
Hi, I was testing a simple uart program, modify from cytron's example of "uart" from "SK40C 18F4520 Sample Program".
The only difference is I try to keep sending the string "OK" out without receiving any characters and I use PIC18F4550.
// Filename: Example_uart.c
// Compiled using MPLAB-C18 v3.34 student edition
// Company   : Cytron Technologies, Malaysia
// Revision   : 1.00
// Date      : 28 Dec 2009
#include <p18f4550.h>
#include "delays.h"
//   Configuration Bits
/** CONFIGURATION **************************************************/
#pragma config PLLDIV   = 5         // (20 MHz crystal on PICDEM FS USB board)
#pragma config CPUDIV   = OSC1_PLL2
#pragma config USBDIV   = 2         // Clock source from 96MHz PLL/2
#pragma config FOSC     = HSPLL_HS
#pragma config FCMEN    = OFF
#pragma config IESO     = OFF
#pragma config PWRT     = OFF
#pragma config BOR      = ON
#pragma config BORV     = 3
#pragma config VREGEN   = ON      //USB Voltage Regulator
#pragma config WDT      = OFF
#pragma config WDTPS    = 32768
#pragma config MCLRE    = ON
#pragma config LPT1OSC  = OFF
#pragma config PBADEN   = OFF
// #pragma config CCP2MX   = ON
#pragma config STVREN   = ON
#pragma config LVP      = OFF
// #pragma config ICPRT    = OFF       // Dedicated In-Circuit Debug/Programming
#pragma config XINST    = OFF       // Extended Instruction Set
#pragma config CP0      = OFF
#pragma config CP1      = OFF
// #pragma config CP2      = OFF
// #pragma config CP3      = OFF
#pragma config CPB      = OFF
// #pragma config CPD      = OFF
#pragma config WRT0     = OFF
#pragma config WRT1     = OFF
// #pragma config WRT2     = OFF
// #pragma config WRT3     = OFF
#pragma config WRTB     = OFF       // Boot Block Write Protection
#pragma config WRTC     = OFF
// #pragma config WRTD     = OFF
#pragma config EBTR0    = OFF
#pragma config EBTR1    = OFF
// #pragma config EBTR2    = OFF
// #pragma config EBTR3    = OFF
#pragma config EBTRB    = OFF
//   Define Pins
#define PIC_CLK 20000000
#define BAUD 9600
//#define DIVIDER ((PIC_CLK/(16UL * BAUD) -1))
#define DIVIDER ((PIC_CLK/BAUD)/16) -1
#define HIGH_SPEED 1
#define LOW_SPEED 0
#define sw1         PORTBbits.RB0      //Active Low
#define sw2         PORTBbits.RB1
//   Function Prototypes
void Delay_1msX (unsigned int miliseconds);
void Delay_100msX (unsigned int msec);
int uart_init(){
   // SPBRGH = 0;
   SPBRG = DIVIDER;                  //set baud rate to 9600 for 20Mhz
   TXSTAbits.BRGH = HIGH_SPEED;      //baud rate high speed option
   TXSTAbits.SYNC = 0;     //Asynchronous mode
   RCSTAbits.SPEN = 1;     //Serial port enable
   RCSTAbits.CREN = 1;     //enable reception.
   TXSTAbits.TX9=0;        //8-bit transmission
   RCSTAbits.RX9=0;        //8-bit reception
   TXSTAbits.TXEN=0;                  //reset transmitter
   TXSTAbits.TXEN=1;                  //enable the transmitter
   TRISC = 0b10000000;   // RC7 = RX = input, RC6 = TX = output
   return 1;
void clear_usart_error(void)
   if (RCSTAbits.OERR)
      TXSTAbits.TXEN=0;
      TXSTAbits.TXEN=1;
      RCSTAbits.CREN=0;
      RCSTAbits.CREN=1;
   if (RCSTAbits.FERR)
      TXSTAbits.TXEN=0;
      TXSTAbits.TXEN=1;
void uart_send(char data)
   while(!PIR1bits.TXIF);
   TXREG = data;
char uart_rec(void)
   while(!PIR1bits.RCIF)
      clear_usart_error();
   return RCREG;
void uart_string(unsigned char *str_ptr)
   while (*str_ptr)
      uart_send(*str_ptr);
      str_ptr++;
   return;
//   Global Variables
unsigned int i, t;
unsigned char data_tx, data_rx;
//   Main Program
void main ()
   //set I/O input output
   TRISB = 0b00000011;               //Configure PORTB I/O direction
   TRISC = 0b10000000;               //Configure PORTC I/O direction
   TRISD = 0b00000000;               //Configure PORTD I/O direction
   PORTB = 0;
   PORTC = 0;
   PORTD = 0;
   // Configure UART
   OpenUSART (USART_TX_INT_OFF &             //Transmit interrupt off
      USART_RX_INT_OFF &                //Receive interrupt off
      USART_ASYNCH_MODE &                //Asynchronous mode - UART
      USART_EIGHT_BIT &                //8-bit transmit/receive
      USART_CONT_RX &                //Continuous reception
      USART_BRGH_HIGH,               //High baudrate
      129);                     //9600 baudrate at 20MHz frequency
   uart_init();
      // UART Transmit
      data_tx='O';                     //Assign data
      uart_send(data_tx);                  //Send data through UART
      data_tx='K';                     //Assign data
}//End of main
//   Subroutines
*       Function Name:  Delay_1msX                                  *
*       Return Value:   void                                        *
*       Parameters:     miliseconds: amount of delay            *
*       Description:    This routine generates various delays       *
*                  needed by xlcd functions.               *
*                  For delay of 1ms (18F4550 running at 48MHz)   *
*                  Cycles = (TimeDelay * Fosc) / 4            *
*                  Cycles = (1ms * 48MHz) / 4               *
*                  Cycles = 12,000                        *
*                  Since call of function also takes some       *
*                  instruction cycles, the exact value to get   *
*                  1ms delay is less than 12,000.            *
   t=0;
   while(t<miliseconds)
      Delay1KTCYx(11);
      Delay10TCYx(96);
      Nop();
      Nop();
      Nop();
      Nop();
      Nop();
      t++;
}//End of Delay_1msX
*       Function Name:  Delay_100msX                                  *
*                  For delay of 100ms                     *
*                  (18F4550 running at 48MHz)               *
*                  Cycles = (100ms * 48MHz) / 4            *
*                  Cycles = 1,200,000                     *
*                  1ms delay is less than 1,200,000.         *
   t=0;
   while(t<msec)
      Delay10KTCYx(119);
      Delay1KTCYx(9);
      Delay10TCYx(96);
      t++;
}//End of Delay_100msX
Then I try to receive the characters from the PC side using a RS232 converter and eventually I receive garbage characters, can anyone help?
In this program, it receive 0xAD for both "O" and "K"...
solved: it should be #pragma config FOSC = HS instead of #pragma config FOSC = HSPLL_HS.
can anyone tell me the reasons?
jeffrey5337
Re: PIC18F uart baud rate problem
Postby yonghui » Fri Mar 04, 2011 12:01 am
most probably incorrect baud rate.
the baud rate generator register value is incorrect
Postby zhenning » Sat Apr 09, 2011 2:57 pm
jeffrey5337 WROTE:Hi, I was testing a simple uart program, modify from cytron's example of "uart" from "SK40C 18F4520 Sample Program".
// Revision   : 1.00
#include "delays.h"
//   Define Pins
#define BAUD 9600
#define LOW_SPEED 0
int uart_init(){
   // SPBRGH = 0;
   return 1;
   if (RCSTAbits.OERR)
      TXSTAbits.TXEN=0;
      TXSTAbits.TXEN=1;
      RCSTAbits.CREN=0;
      RCSTAbits.CREN=1;
   if (RCSTAbits.FERR)
      TXSTAbits.TXEN=0;
      TXSTAbits.TXEN=1;
   TXREG = data;
char uart_rec(void)
   return RCREG;
   while (*str_ptr)
      str_ptr++;
   return;
//   Global Variables
unsigned int i, t;
//   Main Program
void main ()
   PORTB = 0;
   PORTC = 0;
   PORTD = 0;
   // Configure UART
   uart_init();
      // UART Transmit
}//End of main
//   Subroutines
*                  Cycles = 12,000                        *
   t=0;
      Delay1KTCYx(11);
      Delay10TCYx(96);
      Nop();
      Nop();
      Nop();
      Nop();
      Nop();
      t++;
   t=0;
   while(t<msec)
      Delay10KTCYx(119);
      Delay1KTCYx(9);
      Delay10TCYx(96);
      t++;
Look at the datasheet. HS and HSPLL_HS, both are going through a different route. HSPLL_HS, goes through the PLL module, while HS goes directly to CPUDIV to scale the frequency.
zhenning
