is it using relay? voltage regulator?switching regulator? boost-converter circuit or ic?
if there's an IC what is the IC code (the series number)?
all the question same goes to the buck converter..how to lower down the voltage and is there any IC i can used?
i have this project that requires to increase the voltage and connected to a panel..after a button being pressed on,the signal go back to the PIC circuitry..the voltage will be below 5V again..
what IC does have both function ? (boost and buck)..n i hope is a through hole IC not the surface mount pcb
another question, can the PIC being interface with both voltage booster and buck converter and operate contionously..
please help me and show me how to interface it...
