which compiler to use? (new in PIC)
Postby fitri » Mon May 02, 2011 8:34 pm
hi everyone~
im new in PIC, i want to build a prototype of home automation system. i am planning to use PIC16f877a. is that posibble?
And i also dont know which compiler i need to use? one of my friend sugest me to use CCS compiler (it use c language rite?)
i dont realy know how to use it. can somebody give any sugestion?
thx~
regard
fitri.
fitri
Re: which compiler to use? (new in PIC)
Postby Brian Griffin » Mon May 02, 2011 8:36 pm
fitri WROTE:hi everyone~
thx~
regard
fitri.
You can try the Hi-tech compiler for PIC as a good start.
If you are using PIC18F series, use the MPLAB C18 one. :)
Also, aim for the CCS and MikroC if you have some money as the compilers are cheaper than the full version Hi-Tech or the MPLAB C18 ones.
Postby fitri » Mon May 02, 2011 11:15 pm
thx brian,
em..i already have ccs compiler, should i just use it?
and another question..when i create a program, i build a c source file. is that correct? should it be hex file?
i write program in ccs, and then compile it and import it to pickit. is my procedure correct?
thx for ur suggestion ;)
fitri
Postby Brian Griffin » Tue May 03, 2011 12:20 am
No worries about the CCS. It's a very good compiler as well.
Take note that there are two versions of CCS - one is attached with the MPLAB IDE (Integrated development environment) and one is a seperate IDE by itself.
Yes, if you create a program, make sure you "Create New Project" in its respective "Projects" drop down menu.
The compiled C will be in the form of hex file.
Postby shahrul » Tue May 03, 2011 11:32 am
fitri WROTE:thx brian,
You must create project, set compiler, then write code on C file. The hex file compiled by the software.
This example step2 using MPLab.
Postby ober » Wed May 04, 2011 9:24 am
Yup, there are plenty of C compiler for PIC out there. Most of them have their own strength and weakness.
Since you already have CCS on hand, just use it. :)
Postby Brian Griffin » Wed May 04, 2011 4:27 pm
ober WROTE:Yup, there are plenty of C compiler for PIC out there. Most of them have their own strength and weakness.
My only grouse of using the CCS is one have to pay for the 1-year maintenance and renewing it isn't cheap. The 1-year maintenance is for compiler updates and new microcontroller support.
Postby Sab » Tue May 31, 2011 11:25 pm
Hi Experimenters,
Can i used micro C source code and compile in Mplab IDE Hitech C compiler?
Sab
Postby Brian Griffin » Wed Jun 01, 2011 9:45 am
Sab WROTE:Hi Experimenters,
You can but you need to modify the codes. The C between these compilers are slightly different.
Postby Sab » Wed Jun 01, 2011 4:44 pm
Thank you Brian.
Sab
