Problems with LM35
Problems with LM35
Postby Happy3 » Mon Jul 04, 2011 9:43 pm
Hi, I'm facing problem in my project regarding the PR11 temperature monitoring parts. I connect my LM35 to the PIC(16f877a). Unfortunately, the LCD can't show the correct room temperature. May I know which part of my coding having error? Or what coding i actually miss out ? Thanks for helping me ;)
#include<pic.h>
//===============configuration=================================
__CONFIG (0x3F32);
//===============define IO port================================
#define      lcd         PORTB
#define      RS          RA2
#define      E           RA5
#define      CHANNEL0    0b10000001   // AN0
#define      buzzer_led  RD0
#define      fan         RD1
//==============FUNCTION PTOTOTYPE=========================
void e_pulse(void);
void delay(unsigned short i);
void lcd_clr(void);
void increment(unsigned long data);
void read_adc(void);
unsigned short read_temp(void);
//====================MAIN================================
unsigned short result;
unsigned short temp,tempA;
void main(void)
   ADRESH=0;            //clear A/D result
   ADRESL=0;            //clear A/D result
   //setting ADCON1 Register
   ADCON1=0b11000101;         // A/D result right justified,
                             // configure RA2 and RA5 as digital I/O
   TRISA=0b11011011;         //configure PORTA I/O direction
   TRISB=0b00000000;         //configure PORTB as output
   TRISD=0b00000000;         //configure PORTD as output
   PORTA=0;
   PORTB=0;
      send_config(0b00000001);      //clear display at lcd
      send_config(0b00000010);      //Lcd Return to home
      send_config(0b00000110);      //entry mode-cursor increase 1
      send_config(0b00001100);      //diplay on, cursor off and cursor blink off
      send_config(0b00111000);      //function set
      lcd_goto(0);                  //cursor start from beginning
      //display character on LCD
      send_char(' ');
      send_char('T');
      send_char('E');
      send_char('M');
      send_char('P');
      send_char('.');
      send_char('A');
      send_char('=');
      while(1)                  //infinity loop
      //Temperature sensor
      ADCON0=CHANNEL0;         //CHANNEL0=0b10000001
      lcd_goto(8);
      read_adc();
      temp=read_temp();
      dis_num(temp/10);
     send_char('.');
      dis_num(temp%10);
      send_char(0b11011111);
      send_char('C');
      send_char(' ');
      send_char(' ');
      tempA=temp;
           if(tempA>300)
               buzzer_led=1;
               fan=1;
         else if(tempA<250)
               buzzer_led=1;
               fan=0;
         else
               buzzer_led=0;
              fan=0;
      delay(2000);
//==================subroutine LCD setting ==========================
    RS=0;
   lcd=data;
   delay(500);
   e_pulse();
void e_pulse(void)
   E=1;
   delay(500);
   E=0;
   delay(500);
    RS=1;
   lcd=data;
   delay(500);
   e_pulse();
    if(data<16)
       send_config(0x80+data);
   else
       data=data-20;
      send_config(0xc0+data);
void lcd_clr(void)
   RS=0;
    send_config(0x01);
   delay(600);
   unsigned char hundred_thousand;
   unsigned char ten_thousand;
   unsigned char thousand;
   unsigned char hundred;
   unsigned char tenth;
   hundred_thousand = data/100000;
   data = data % 100000;
   ten_thousand = data/10000;
   data = data % 10000;
   thousand = data / 1000;
   data = data % 1000;
   hundred = data / 100;
   data = data % 100;
   tenth = data / 10;
   data = data % 10;
   if(hundred_thousand>0)
      send_char(hundred_thousand + 0x30);   //0x30 added to become ASCII code
      send_char(ten_thousand + 0x30);
      send_char(thousand + 0x30);
      send_char(hundred + 0x30);
      send_char(tenth + 0x30);
      send_char(data + 0x30);
   else if(ten_thousand>0)
      send_char(ten_thousand + 0x30);   //0x30 added to become ASCII code
   else if(thousand>0)
       send_char(thousand + 0x30);      //0x30 added to become ASCII code
   else if(hundred>0)
       send_char(hundred + 0x30);      //0x30 added to become ASCII code
   else if(tenth>0)
      send_char(tenth + 0x30);      //0x30 added to become ASCII code
   else send_char(data + 0x30);         //0x30 added to become ASCII code
   unsigned short j;
   for(j=10;j>0;j--)
   {   lcd_goto(32);
      data=data+1;
      dis_num(data);
      delay(10000);
//==================subroutine ADC=========================
void read_adc(void)
   unsigned short i;
   unsigned long result_temp=0;
   for(i=2000;i>0;i-=1)            //looping 2000 times for getting average value
       ADCON0bits.GO = 1;
   //ADGO is the bit 2 of the ADCON0 register
   while(ADCON0bits.GO==1);
   //ADC start, ADGO=0 after finish ADC progress
   result=ADRESH;
   result=result<<8;
   //shift to left for 8 bit
   result=result|ADRESL;
   //10 bit result from ADC
   result_temp+=result;
   result = result_temp/2000;         //getting average value
    unsigned short temp;
   temp=result;
   return temp;
//==================subroutine DELAY==========================
   for(;i>0;i--);
Happy3
Re: Problems with LM35
Postby shahrul » Mon Jul 04, 2011 10:00 pm
What is it display and what is your observation?
I did't check your code.
Postby Happy3 » Mon Jul 04, 2011 10:05 pm
after i made some changes on the coding ,
temp=result*5/1024;
return temp;
the LCD display o.1 degree celsius
Happy3
Postby hyng » Tue Jul 05, 2011 9:58 am
May i know what is the problem? What is show in the LCD? only 0.1 degree everytime?
Postby robosang » Tue Jul 05, 2011 10:41 pm
Not everyone have the hardware to verify your code, and I am sure no one like to check code 8-)
So please elaborate your problem clearly so other can help you.
Please list out what have you done, from original code to the modification you have made.
Also what is the result/output after you load the modified code.
Postby Brian Griffin » Tue Jul 05, 2011 11:45 pm
We need to see the circuit diagram and the offensive code bolded. :)
Do you have a voltage reference? Or is it at the default +5V?
