Microsoft SQL data transfer to EEPROM
Postby PICTRAIL » Tue Aug 16, 2011 1:45 pm
Here i come again. I appreciate you all for the ever ready help.
I have a table in Ms SQL with 8 character per row. I want to transfer this data to PIC16F877A EEPROM through Visual Basic 2008.
Any resources on this would highly be appreciated. Thanks.
Btw, i'm using UART to USB communication channel.
Regards!
PICTRAIL
Re: Microsoft SQL data transfer to EEPROM
Postby Brian Griffin » Tue Aug 16, 2011 2:02 pm
PICTRAIL WROTE:Here i come again. I appreciate you all for the ever ready help.
Regards!
I used excel to compile the data, and stowed it in an SPI EEPROM. Not sure whether this would work in your configuration or not though.
Postby PICTRAIL » Tue Aug 16, 2011 2:11 pm
Kindly shed more light on the excel - Spi communication. Both receive and transmit. I'm sure it will be useful.
PICTRAIL
Postby Brian Griffin » Tue Aug 16, 2011 2:18 pm
PICTRAIL WROTE:Kindly shed more light on the excel - Spi communication. Both receive and transmit. I'm sure it will be useful.
I used a manual method - use excel to tabulate the data, then convert into a text file with commas.
Then I programmed the EEPROM chip (SPI interface) using my Pickit2. A modification of the compiler is done, which is very tedious and not really recommended.
Postby PICTRAIL » Tue Aug 16, 2011 2:28 pm
Oh i see... Nice concept. Pls any sample code for SPI read and write?...
PICTRAIL
