ober WROTE:All the sample source code under DIY project were tested with the real circuit and component as shown in the detail description before we launched. So it is working sample code. Especially, PR11 as many has been using and modifying it.
A photo of the hardware is much more appreciated, the photo will give us some idea where might the cause be.
altron11 WROTE:Hi Ober,
If i were to use a PT100 2-wire sensor instead of the lm35, can i connect to RA0 of the PIC as per PR11? Do i need to connect any other components?
ober WROTE:altron11 WROTE:Hi Ober,
I am not familiar with PT100 2-wire sensor. Any link or datasheet explaining specification on this sensor?
altron11 WROTE:I am unable to upload the datasheet as it is in pdf format. As follow is the link to the sensor. I am using the DM-303 model.
http://sg.element14.com/labfacility/dm- ... tt=1289667
TeoYX WROTE:In this project, RA3 is as the Vref for the analogue sensor? If without this, can the sensor work too
