ps2 controller starter kit
Postby gorgom » Sat Oct 15, 2011 11:38 pm
anyone can debug this code? PIC16f628A cannot communicate with SKPS.
#include <pic.h>
//   configuration
__CONFIG ( 0x3F10  );      //configuration For PIC16F628A
//   define
#define _XTAL_FREQ   12000000      //Fosc=12MHz
#define motor_ra   RB6
#define motor_rb   RB7
//skps protocol
#define p_select      0
#define p_joyl         1
#define p_joyr         2
#define p_start         3
#define p_up         4
#define p_right         5
#define p_down         6
#define p_left         7
#define p_l2         8
#define p_r2         9
#define p_l1         10
#define p_r1         11
#define p_triangle      12
#define p_circle       13
#define p_cross         14
#define p_square      15
#define p_joy_lx      16
#define p_joy_ly      17
#define p_joy_rx      18
#define p_joy_ry      19
#define p_joy_lu      20
#define p_joy_ld      21
#define p_joy_ll              22
#define p_joy_lr              23
#define p_joy_ru      24
#define p_joy_rd      25
#define p_joy_rl              26
#define p_joy_rr      27
#define p_con_status           28
#define p_motor1      29
#define p_motor2      30
//   global variable
//   function prototype
void init(void);
unsigned char uart_rec(void);
unsigned char skps(unsigned char data);
void skps_vibrate(unsigned char motor, unsigned char value);
//   interrupt prototype
//   main function
void main(void)
   init();         //initialize microcontroller
      //test button for horn
      if((skps(p_l1)==0)||(skps(p_l2)==0)||(skps(p_r1)==0)||(skps(p_r2)==0)||(skps(p_triangle)==0)||(skps(p_circle)==0)) motor_ra=1;
      else if((skps(p_up)==0)||(skps(p_down)==0)||(skps(p_right)==0)||(skps(p_left)==0)||(skps(p_cross)==0)||(skps(p_square)==0)) motor_rb=1;
      else
         motor_ra=0;
         motor_rb=0;
// initailization
void init()
   CMCON = 0b00000111;            // disable comparators
   // Tris configuration (input or output)
   TRISA = 0b00000001;            //set RA0 pin as input,other as output
   TRISB = 0b00000010;            //set PORTB as output
   //setup USART
   SPBRG = 0x4D;                  //set baud rate to 9600 for 12Mhz
   BRGH = 1;                     //baud rate high speed option
   TXEN = 1;                     //enable transmission
   TX9 = 0;
   CREN = 1;                     //enable reception
   SPEN = 1;                     //enable serial port
   RX9 = 0;
   RCIE = 0;                     //disable interrupt on eachdata received
   // enable all unmasked interrupt
   GIE = 0;
   PEIE = 0;
   motor_ra = 0;
   motor_rb = 0;
// uart function
void uart_send(unsigned char data)   //function to send out a byte via uart
   while(TXIF==0);               //wait for previous data to finish send out
   TXREG=data;                  //send new data
unsigned char uart_rec(void)      //function to wait for a byte receive from uart
   unsigned char temp;
   while(RCIF==0);               //wait for data to received
   temp=RCREG;
   return temp;               //return the received data
// skps function
unsigned char skps(unsigned char data)         //function to read button and joystick
{                                    //information on ps controller
   uart_send(data);
   return uart_rec();
{                                    //function to control the vibrator motor
   uart_send(motor);                     //on ps controller
   uart_send(value);
gorgom
Re: ps2 controller starter kit
Postby shahrul » Sun Oct 16, 2011 12:10 am
You can try this code SKPS.
Postby gorgom » Sun Oct 16, 2011 12:10 pm
Thanks for the reply. I have no problem communicate skps with PIC16F877A. I just want to try communicate the skps with PIC16F628A but there are no response when I press the PS2 controller key. pic-lesson-uart-module show coding for PIC16F887. I just wonder whats wrong in my coding. I will do some adjustment according to the given example. Please show me if some one out there find any error in my coding. Thanks.
gorgom
Postby gorgom » Sun Oct 16, 2011 12:55 pm
Thanks shahrul. After examine your coding. The problem of my program is just the configuration bits. I should use HS oscillator. SKPS communicate with PIC16F628A succeed.
gorgom
