Hello Cytroners ;
I'm asking for AN809 , AN811 and IR2159 or any project that's related to DALI(Digital Addressable Lighting Interface)..
robosang WROTE:Brother, what is AN809 and other code? You are looking for IC or document?
shahrul WROTE:Is this document you need AN809
waddah WROTE:Digitally Addressable DALI Dimming Ballast. It's a tool used in dimming lighting systems , PIC16F628 together with IR2159 HVIC Ballast Controller..
robosang WROTE:waddah WROTE:Digitally Addressable DALI Dimming Ballast. It's a tool used in dimming lighting systems , PIC16F628 together with IR2159 HVIC Ballast Controller..
Please be specificWe do not know what you mean by just putting the code and number.
You should look at the document, it should pointed you to get the kit.
waddah WROTE:yup, that's exactly what I want, the kit. That kit is AN809..
If you opened the doc, you should've seen it.. I wonder where it is available
waddah WROTE:robosang WROTE:Brother, what is AN809 and other code? You are looking for IC or document?
