Push ON switch to turn "ON" and "OFF" LED.
Postby mdfarizal » Thu Nov 24, 2011 2:32 pm
Very simple question, but i have difficulty to sort it out.
with one push ON button how i can program it (in C language) to turn ON and OFF a LED in single push.
First time Push -> LED = ON,
Second time Push -> LED = OFF,
Third time Push -> LED = ON,
4th time Push -> LED = OFF,
repeated....
Thanks....
mdfarizal
Re: Push ON switch to turn "ON" and "OFF" LED.
Postby Brian Griffin » Thu Nov 24, 2011 3:29 pm
There is a thing in the C language called "toggle". <- The hint is already there.
Postby robosang » Fri Nov 25, 2011 9:23 am
You say you have difficulty to sort it out, so what is the difficulty? Any code to show us and what is the response?
Yup, brian is pointing you to correct direction, but I just want add some extra idea :mrgreen: , you might need debouncing algorithm to wait for switch to release. Again, I will not give answer, just guidance. Try to find and try it, that's learning.
Postby ZaM » Mon Nov 28, 2011 12:29 pm
if(RB0==0)
led1 != led1;
ZaM
Postby ZaM » Mon Nov 28, 2011 12:31 pm
if(sw1==0)
while(sw1==0); //wait button release
led1 != led1;
ZaM
Postby robosang » Mon Nov 28, 2011 9:44 pm
ZaM WROTE:if(sw1==0)
led1 != led1;
So what is the outcome of this code? How is the LED response if this code is being written into PIC?
Postby ZaM » Tue Nov 29, 2011 12:25 am
sorry, tq robosang
int constant=1;
while(1) //condition for looping 1-true, 0-false
led = constant;
if(sw1==0)
while(sw1==0);
constant = !constant;
ZaM
