wired controller servo
Postby safuwan jasni » Thu Dec 08, 2011 6:58 pm
i'm using sk40c, 8channel servo and 7 servo motor. thus, i need to control only one servo from that 7.. how to interface between sk4oc, 8channel servo, ps 2 controller, and SKPS..
safuwan jasni
Re: wired controller servo
Postby ober » Fri Dec 09, 2011 9:55 am
8 channel servo controller? The SC08A? and SKPS? Both SC08A and SKPS use UART to communicate with host, therefore you will need 2 UART on the microcontroller.
1st try to figure out how to interface. SKPS to PS2 is very straight forward. Just connect the PS2 plug to SKPS's socket. While referring to SKPS User's Manual (where you can download from SKPS product page for details. You can also refer to one of our tutorial project on using SK40C, project 15 for sample connection.
For SK40C to SC08A, you can again refer to the User's Manual or another tutorial about Assembly of Small Robot Gripper.
Get familiar with separated system first, and try to integrate 2 system using PR27:multi-UART example. Since SC08A and SKPS will depend on microcontroller command, using software UART should not create issue.
Good luck.
Postby royalstorm7 » Thu Dec 15, 2011 12:20 am
hi safuwan jasni
u can generate a lot of PWM signal from the SKC40C so it not necessary to jumbletrouble a lot of hardware....
tq
roslan
royalstorm7@yahoo.com
find me in facebook
royalstorm7
