IFC EEPROM read/write & init
Posted: Fri Dec 16, 2011 11:24 am
Good day~
i am using IFC card,
I need to write and read to PIC EEPROM.
i am using MPLAB C18
1)
I got the sample code from the internet for EEPROM data initialization to initialize the EEPROM data to certain value when it program.
but i got error on line "psect eedata,delta=2.abs,ovrld..."
May i know how to correct the error as i totally dont know what is it doing?
pls refer to below code.
2)
Any sample code / library function for IFC card /PIC18F2685 for the EEPROM data read/write and initialization?
3)
i see in the code below there is one line "org 2100h", is that refer to the address of the EEPROM start?
when i want to write /read the EEPROM, i should use starting address of 0x0000 or 0x2100?
i tried to look in the datasheet to see where the EEPROM address start, but i cant find the info.
4)
can i save this code as EEPROM_init.c and include that using #include EEPROM_init.c in my main program? or must be .h file?
pls advise and thanks.
Good day~
1)
2)
3)
4)
- CODE: SELECT_ALL_CODE
//[user change]
#define PROFILE 0 //0 for normal setup
//1 for EEPROM filled with zeros
//[do not alter]
#if (PROFILE!=0) && (PROFILE!=1)
#error eep_init 13
#endif
#asm
psect eedata,delta=2,abs,ovrld
org 2100h
#endasm
#if (PROFILE==0)
#asm
db '1',0x03,'2',0x04,0x00,0x00,0x00,0x00
db 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00
db 0x23,0x56,0x00,0x00,0x00,0x00,0x00,0x00
#endasm
#endif
#if (PROFILE==1) //nothing in EEPROM
#asm
#endasm
#endif
