helpp!!! PIC 16F877A + PIR SENSOR
Postby davidrefi » Mon Dec 26, 2011 11:17 am
hiii all master, i'am newbie, anyone know , how to connect PIC 16F877A with PIR SENSOR interface(code) , i'am using Hitech compiler in MPLAB.thx :cry:
davidrefi
Re: helpp!!! PIC 16F877A + PIR SENSOR
Postby ABSF » Mon Dec 26, 2011 12:39 pm
You can refer to the schematics and software here
PR14
Postby shahrul » Mon Dec 26, 2011 2:00 pm
This is only digital input. See this PIR example.
Postby davidrefi » Mon Dec 26, 2011 2:14 pm
mr.shahrul. i'am still blur... i just wanna connected SK40C(pic 16F877A) to my PIR sensor, so that mean my sensor can work using the interface(code) from MPLAB.
bcoz in ur blog u mix buzzer + pir, so that code make me confused.thx
davidrefi
Postby shahrul » Mon Dec 26, 2011 3:07 pm
davidrefi WROTE:mr.shahrul. i'am still blur... i just wanna connected SK40C(pic 16F877A) to my PIR sensor, so that mean my sensor can work using the interface(code) from MPLAB.
The buzzer and PIR connected to PIC.
Postby robosang » Wed Dec 28, 2011 9:12 am
Study the schematic, and the code... take off those not in use.
Microcontroller is combination of hardware and software, but must be correct in order to work ;)
Postby ZaM » Thu Dec 29, 2011 7:28 pm
PIR output pin is digital output same as normal switch, except PIR have delay when trigger.. try this, RB0= PIR output pin
if(RB0=0)
do_something;
ZaM
Postby robosang » Thu Dec 29, 2011 9:22 pm
ZaM WROTE:PIR output pin is digital output same as normal switch, except PIR have delay when trigger.. try this, RB0= PIR output pin
if(RB0=0)
do_something;
the code... should be
If (RB0 == 0)
do something
