HELP! How to interface encoder of SPG30E-200K to PIC
Postby boonthiam89 » Sat Mar 10, 2012 12:43 pm
Guys, I have problem which is the interrupt routine seems is not working. This is 4X quadrature encoding.Can help me to check whether there is any error in my programming code? The interrupt is used to count the position of the motor. Motor used is SPG30E-200K and it is connected to PIC as in the schematic diagram in the detail of the motor.
#define IN3 PortC.F4 // IN3 and IN4 is refering to the ports of L293D motor driver
#define IN4 PortC.F7
#define A PortB.F1 // A & B is the ports of encoder from the DC motor
#define B PortB.F2
#define EN2 CCPR2L
unsigned long int volt1,volt2,state0=0,state1=0;
signed long int CountValue=0;
void interrupt (void){
if(INTCON3.INT1IF==1)
    INTCON2.INTEDG1^=1;
    INTCON3.INT1IF=0;
else if (INTCON3.INT2IF==1)
    INTCON2.INTEDG2^=1;
    INTCON3.INT2IF=0;
state1=((B*2)+A);
switch(state1)
case 0:
     if(state0==1) CountValue++;
     else CountValue--;
     break;
case 1:
     if(state0==3) CountValue++;
     else CountValue--;
     break;
case 2:
     if(state0==0) CountValue++;
     else CountValue--;
case 3:
     if(state0==2) CountValue++;
     else CountValue--;
     break;
State0=state1;
void main(void)
TRISA = 0b11100111;
TRISB = 0b00000110;
TRISC = 0b00000000;
ADCON0 = 0b01000001;
ADCON1 = 0b11000000;
CCP2CON = 0b00001100;
PR2 = 0xFF;
T2CON = 0b00000101;
INTCON2.INTEDG1 = 1;
INTCON2.INTEDG2 = 1;   //Enable Change on INT1 interupt
INTCON3.INT1IP = 1;
INTCON3.INT2IP = 1;    //Enable Change on INT1 interupt LOW PRIORITY
INTCON3.INT1IF = 1;
INTCON3.INT2IF = 1;    //Clear flag
INTCON3.INT1IE = 1;
INTCON3.INT2IE = 1;   //Enable INT1 interupt source
INTCON.GIEL = 1;       //Enable All low priority interupts
INTCON.GIEH = 1;       //Enable All interupts
INTCON.RBIE = 1;       //Enable Change on PortB interupt
volt1 = ADC_Read(0);
delay_ms(20);
volt2 = ADC_Read(1);
delay_ms(20);
if(volt1>=205 || volt2>=205)
   if (volt1<=(volt2+5)&&volt1>=(volt2-5))
   delay_ms(5000);
   else if (volt1>volt2)
        IN3=1;
        IN4=0;
        delay_ms(20);
        EN2=200;
        IN3=0;
        delay_ms(100);
   else if(volt1<volt2)
        IN4=1;
        IN3=0;
        delay_ms(20);
        EN2=200;
        IN4=0;
        delay_ms(100);
else
    if(CountValue==0)
    delay_ms(15000);
    else if(CountValue > 0)
          do
            IN3=1;
            IN4=0;
            EN2=200;
            IN3=0;
            delay_ms(20);
          while(CountValue!=0);
    else if(CountValue < 0)
           do
             IN3=0;
             IN4=1;
             EN2=200;
             IN4=0;
             delay_ms(20);
boonthiam89
Re: HELP! How to interface encoder of SPG30E-200K to PIC
Postby sich » Sun Mar 11, 2012 6:35 pm
What microcontroller are you using? Is it the same with the example application by Cytron?
Postby boonthiam89 » Sun Mar 11, 2012 9:06 pm
PIC 18F452 and using micro C PRO
boonthiam89
Postby A380 » Sun Mar 18, 2012 7:05 pm
In your main(void) function, some configuration were wrong.. change it as below:
INTCON3.INT1IF = 0;
INTCON3.INT2IF = 0; //Clear flag
INTCON.RBIE = 0; //Enable Change on PortB interupt
case 2:
else CountValue--;
break;
you forgot place a "break;" there.
A380
