EEPROM write and read
PostPosted: Sun Apr 29, 2012 4:56 pm
by compass1982
Hi all,
i had wrote a simple code of storing a value into 16F877A EEPROM. the code is as below:
define osc 20
start:
WRITE 0,3
the value of "3" suppose to be written into the EEPROM location of 0000 right? may i know how can i verify the written EEPROM by using pickit2?
(i am using pic basic pro to comple the code, may i know is there any extra header need to be declared?)
thanks~~!
Re: EEPROM write and read
PostPosted: Sun Apr 29, 2012 8:34 pm
by yonghui
pickit can read the memory content of the PIC, just click on read button on pickit2 standalone software.
i was using function call to write and read eeprom of PIC.
normally i check by writing the memory, and reading it back and compare if the read value is same. if same light up the LED, or display the content on LCD.
PostPosted: Sun Apr 29, 2012 11:44 pm
by compass1982
Can u show me an example code on how to do this? U r also using pic basic?
PostPosted: Thu May 03, 2012 5:44 pm
by zhenning
Dim Write_Value as byte
Dim Read_Value as byte
Write_Value = $10
Read_Value = 0
EWrite 0, [Write_Value] 'Write the contents of 'Write_Value' variable to address 0
Read_Value = ERead 0 'Read the contents from address 0 to Read_Value variable
