can anyone help for communicate 2 stepper motor 1 gsm modem
Postby prince24 » Tue May 01, 2012 1:09 am
this is my stepper motor
http://www.cytron.com.my/viewProduct.php?pcode=SD02B&name=Enhanced%202A%20Stepper%20Motor%20Driver
this is my pic 16f877a
http://www.cytron.com.my/viewProduct.php?pcode=SK40C&name=Enhanced%2040%20pins%20PIC%20Start-Up%20Kit
this is my gsm modem with connect onto max232
http://www.cytron.com.my/viewProduct.php?pcode=MOD-9001D&name=RS232%20GSM/GPRS%20Modem
and im also have ir sensor as object detector
so can anyone tells me how much pic really i needed to control all those things. or i can just using 1 pic. if can wheres the point of connection that i can plug in? because as i notice the stepper driver using uart at point r3,r4,r6 and r7 as rx and tx. so then my gsm modem also need the rx and tx same goes to my ir sensor.
thankz for ur helps and cooperation.
prince24
Re: can anyone help for communicate 2 stepper motor 1 gsm mo
Postby zhenning » Thu May 03, 2012 5:58 pm
Depends on your selection of your solution,
You can use software uart if the hardware uart is not enough. You can also switch to a PIC which has more uart.
zhenning
