LCD wont display
LCD wont display
Postby shinigami.alv » Tue May 15, 2012 12:36 am
im using SK40C to display my LCD but all i got is only black screen on the first line. im using (16x2) LCD. below is my code, am i missing something?
#include <pic.h>
__CONFIG ( 0x3F3A );
#define   lcd_data      PORTD
#define rs            RB4
#define e            RB5
void Init(void);
void lcd_clr(void);
void e_pulse(void);
void main(void)
   Init();
   lcd_clr();
   lcd_goto(0);                           // clear the LCD screen
   send_string("helo");
   lcd_goto(20);                           // move to 2nd line
   send_string ("helo");
void Init(void)
   TRISD = 0b00000000; //output
   TRISB = 0b11111111;  //input
   PORTB = 0;
  //configure lcd
   send_config(0b00000001);         //clear display at lcd
   send_config(0b00000010);         //lcd return to home
   send_config(0b00000110);         //entry mode-cursor increase 1
   send_config(0b00001100);         //display on, cursor off and cursor blink off
   send_config(0b00111000);         //function set
void delay(unsigned long data)         //short delay
{                              //delay lenght according to the given value
   for( ;data>0;data-=1);
   rs=0;                        //clear rs into config mode
   lcd_data=data;
   delay(50);
   e_pulse();
   rs=1;                        //set rs into write mode
   lcd_data=data;
   delay(50);
   e_pulse();
void e_pulse(void)
   e=1;
   delay(50);
   e=0;
   delay(50);
    if(data<16)
       send_config(0x80+data);
   else
       data=data-20;
      send_config(0xc0+data);
void lcd_clr(void)
    send_config(0x01);
   delay(50);
   //unsigned char i=0;
shinigami.alv
Re: LCD wont display
Postby ABSF » Tue May 15, 2012 6:33 am
shinigami.alv WROTE:im using SK40C to display my LCD but all i got is only black screen on the first line. im using (16x2) LCD. below is my code, am i missing something?
Are you running at 20MHz? I'd say the delay(50) is too short...,,, Try delay(2000) and see if it works.
Postby shinigami.alv » Tue May 15, 2012 12:05 pm
Hi Allan, i tried that but still not working. nothing appears on the screen. could it be the code problem?
shinigami.alv
Postby ober » Tue May 15, 2012 3:58 pm
Is the code problem... you connect the LCD RS and LCD E at port B, but your TRISB show all pins at PORTB is input. Try to change that particular pin to become output.
Postby shinigami.alv » Tue May 15, 2012 9:14 pm
ya, the delay and RS & E are the problems. i tried and found out that delay(700) is the shortest that 20M can support. thanks guys for the help. :)
shinigami.alv
Postby ABSF » Tue May 15, 2012 9:42 pm
Glad to hear that you've solved your problem.... :)
My code also facing same problem...can help?
Postby choohao » Sat Nov 03, 2012 7:46 pm
//        Author                                        : CYTRON
//        Project                                        : SK40C Led Blinking
//        Project description                : Blink RB6 and RB7 LED
//                                                          This sample source code is valid for 20MHz crystal.
//        include
#include <pic.h>
//configuration
__CONFIG ( 0x3F32 );                //configuration for the  microcontroller
//        define
#define        rs                        RB4                        //RS pin of the LCD display
#define        e                        RB5                        //E pin of the LCD display
#define        lcd_data        PORTD                //LCD 8-bit data PORT
#define        SW1                        RB0
#define        SW2                        RB1
#define        LED1                RB6
#define        LED2                RB7
//        function prototype                (every function must have a function prototype)
void lcd_clr(void);
//        global variable
//        main function                                        (main fucntion of the program)
void main()
        unsigned long delay_time=5000;
        //set I/O input output
        TRISB = 0b00000000;                                //configure PORTB I/O direction
        TRISD = 0b00000000;                                //configure PORTD I/O direction
        TRISA = 0b00000111;                                //configure PORTA I/O direction
        //setup ADC
        ADCON1 = 0b00000110;                                //set ADx pin digital I/O
        //configure lcd
        //display startup message
        lcd_clr();                                                        //clear lcd
        lcd_goto(2);                                                //set the lcd cursor to location 0
        send_string("Cytron Tech.");                //display "Cytron Tech."
        lcd_goto(26);                                                //set the lcd cursor to location 20
        send_string("SK40C");                                //display "SK40C"
        LED1=0;        //OFF LED1
        LED2=0;        //OFF LED2
        while(1)                                                        //Infinite loop
                if(!SW1)                                                //check if SW1 is pressed
                        while (!SW1);                                //wait SW1 pressed
                                delay_time+=1000;                //delay
                else if(!SW2)                                        //check if SW2 is pressed
                        while (!SW2);                                //wait SW2 pressed
                                delay_time-=1000;                //delay
                LED1^ = 1;                                        //toggle LED1
                delay(delay_time);
                LED2^ = 1;                                        //toggle LED2
                delay(delay_time);
//        functions
void delay(unsigned long data)                        //delay function, the delay time
{        //depend on the given value
        for( ;data>0;data--);
void send_config(unsigned char data)        //send lcd configuration
        rs=0;        //set lcd to configuration mode
        lcd_data=data;                                                //lcd data port = data
        e=1;        //pulse e to confirm the data
        delay(50);
        e=0;
        delay(50);
void send_char(unsigned char data)                //send lcd character
         rs=1;        //set lcd to display mode
        delay(10);
        e=0;
        delay(10);
void lcd_goto(unsigned char data)                //set the location of the lcd cursor
{        //if the given value is (0-15) the
         if(data<16)                                                        //cursor will be at the upper line
        {        //if the given value is (20-35) the
                 send_config(0x80+data);                        //cursor will be at the lower line
        }        //location of the lcd cursor(2X16):
        else        // -----------------------------------------------------
        {        // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
                 data=data-20;                                        // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
                send_config(0xc0+data);                        // -----------------------------------------------------
void lcd_clr(void)                                                //clear the lcd
         send_config(0x01);
        delay(600);
void send_string(const char *s)                        //send a string to display in the lcd
        while(TXIF==0);                                                //only send the new data after
        TXREG=data;                                                        //the previous data finish sent
choohao
Postby zhenning » Sat Nov 03, 2012 8:08 pm
choohao WROTE:
//        Author                                        : CYTRON
//        include
#include <pic.h>
//configuration
//        define
#define        SW1                        RB0
#define        SW2                        RB1
#define        LED1                RB6
#define        LED2                RB7
void lcd_clr(void);
//        global variable
void main()
        //setup ADC
        //configure lcd
        LED1=0;        //OFF LED1
        LED2=0;        //OFF LED2
                delay(delay_time);
                delay(delay_time);
//        functions
        delay(50);
        e=0;
        delay(50);
        delay(10);
        e=0;
        delay(10);
         send_config(0x01);
        delay(600);
What is the problem? Mind describing a bit instead of just posting the codes? :roll:
zhenning
Postby robosang » Sat Nov 03, 2012 9:09 pm
Yup.... I would like to know too... it seem like we know what are you asking :)
Postby mohdismiaswaly » Mon Nov 05, 2012 6:04 pm
I a newbie here..how to post thread here?
Cannot find any button to click... :roll:
TQ
mohdismiaswaly
