zhenning WROTE:Mplab can only compile assembly code .asm to .hex. In order to compile c code you need to download c compiler such as hi tech c, c18, CCS C and etc. These will act as plugins to mplab. So, in your case, if i am not mistaken, mikrobasic is a standalone program which allows you to compile hex from basic language
sxmplab WROTE:zhenning WROTE:Mplab can only compile assembly code .asm to .hex. In order to compile c code you need to download c compiler such as hi tech c, c18, CCS C and etc. These will act as plugins to mplab. So, in your case, if i am not mistaken, mikrobasic is a standalone program which allows you to compile hex from basic language
could MPLAB compile hex from basic language too?
zhenning WROTE:sxmplab WROTE:zhenning WROTE:Mplab can only compile assembly code .asm to .hex. In order to compile c code you need to download c compiler such as hi tech c, c18, CCS C and etc. These will act as plugins to mplab. So, in your case, if i am not mistaken, mikrobasic is a standalone program which allows you to compile hex from basic language
Nope. You need basic compiler to do that.
zhenning WROTE:You can follow the following guide to compile your basic code:
http://www.mikroe.com/pdf/mikrobasic/1s ... _basic.pdf
sxmplab WROTE:zhenning WROTE:You can follow the following guide to compile your basic code:
i found this code from internet, i use mikcobasic but fail with many error...
http://electronics-diy.com/schematics/721/main.c
