using PIC16F877A Automatic Fan Speed using Temperature (LM3)
Postby aramaitii » Sun Sep 02, 2012 11:42 am
Hi guys,
I want to build PR11 but using PIC16F877A , and I have started study on this matter, but I not clear do I had to change power supply for this circuit or maintain power supply circuit was provided in PR11?.any idea and suggestion.
aramaitii
Re: using PIC16F877A Automatic Fan Speed using Temperature (
Postby zhenning » Sun Sep 02, 2012 12:20 pm
Most of the power supply need not to be changed unless it's a mcu that uses different power supply. Please check the configuration word and pinout. Some of the PIC differ from one series to another.
zhenning
Postby aramaitii » Mon Sep 03, 2012 9:08 am
yes. I still use same power supply, but i don't understand for PIC16F876A only use 1 port VDD and 2 port VSS and PIC16F877A using 2 port VDD and VSS ..do I need to just connect both VDD and VSS to the source and ground? .actually, I just want to change the LCD portC connection to portD, in details, i want to change RC0-RC7 with RD0-RD7 for LCD connection..
aramaitii
Postby Idris » Mon Sep 03, 2012 11:55 am
Yes just connect VDD to 5V and VSS to GND. You can change PORT for LCD connection from C to D, since the SK40C is using the PORTD, you can refer the coding on SK40C page/tutorial.
Postby aramaitii » Mon Sep 03, 2012 7:33 pm
oh ,ok guys.
i get it. tq . :P
aramaitii
Postby hamdi_nik » Mon Mar 28, 2016 12:55 pm
I have bought temperature control system using LM35 (PR11). After, I have wire up my project with all the component according to schematic. But now its not working,LCD only can see light up, the rest whole project not working LM35 and reset button also cant function
hamdi_nik
Postby hamdi_nik » Mon Mar 28, 2016 1:00 pm
I have bought temperature control system using LM35 (PR11). After, I have wire up my project with all the component according to schematic. But now its not working,LCD only can see light up, the rest whole project not working LM35 and reset button also cant function. in MPLAB IDE that code failed to build
Build C:\Users\Hamdi Nik\Desktop\project\project for device 16F877A
Using driver C:\Program Files (x86)\HI-TECH Software\PICC\9.80\bin\picc.exe
Make: The target "C:\Users\Hamdi Nik\Desktop\project\PR11.p1" is out of date.
Executing: "C:\Program Files (x86)\HI-TECH Software\PICC\9.80\bin\picc.exe" --pass1 "C:\Users\Hamdi Nik\Desktop\DIY-PR11-PIC16F876A-master\PIC16F876A DIY PR11\Source File\PR11.c" -q --chip=16F877A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error [192] C:\Users\Hamdi Nik\Desktop\DIY-PR11-PIC16F876A-master\PIC16F876A DIY PR11\Source File\PR11.c; 322.1 undefined identifier "GO"
********** Build failed! **********
hamdi_nik
Postby Nurul.Syuhada » Mon Mar 28, 2016 3:42 pm
Hi Hamdi.
The error that you get is due to the source code is not compatible with the compiler that you used. You can download the updated source file in this Github Link.
Sorry for the inconvenience. :)
Nurul.Syuhada
Postby hamdi_nik » Wed Apr 06, 2016 8:33 am
Nurul.Syuhada WROTE:Hi Hamdi.
thanks a lot to Nurul.Syuhada
I have done this project successful. I want to ask something. It is possible if i replace the temperature sensor with humidity sensor (hr202 or dht11)?
hamdi_nik
Postby Apis210 » Wed Apr 06, 2016 3:20 pm
Possible and you need to modify the code accordingly. :ugeek:
Apis210
