using PIC16F877A Automatic Fan Speed using Temperature (LM3)
Re: using PIC16F877A Automatic Fan Speed using Temperature (
Postby HollyJuster » Thu Jul 07, 2016 12:47 am
Hi everyone..!! Actually i still use same power supply, but i don't understand for PIC16F876A only use 1 port VDD and 2 port VSS and PIC16F877A using 2 port VDD and VSS ..do I need to just connect both VDD and VSS to the source and ground? .actually, I just want to change the LCD portC connection to portD, in details, i want to change RC0-RC7 with RD0-RD7 for LCD connection.Also i would like to say that just connect VDD to 5V and VSS to GND. You can change PORT for LCD connection from C to D, since the SK40C is using the PORTD,
HollyJuster
Postby anhtran19932111 » Thu Aug 25, 2016 5:52 pm
I want to change RC0-RC7 with RD0-RD7 for LCD connection.
anhtran19932111
Postby anhtran19932111 » Tue Sep 06, 2016 3:34 pm
I just connect VDD to 5V and VSS to GND.
anhtran19932111
Postby ZaM » Tue Sep 06, 2016 5:55 pm
anhtran19932111 WROTE:I want to change RC0-RC7 with RD0-RD7 for LCD connection.
Hi, yes you can change LCD from port C to port D but minimal code changes is needed for example Port declaration TRISC to TRISD. Make sure to refer Datasheet for more info or you can compare code sample code from SK40C because SK40c use port D for LCD.
ZaM
Users browsing this forum: No registered users and 173 guests
