robosang WROTE:My concern is more at the USB driver, not sure have Microchip release driver for Webcam.... I know they have release some USB class such as HID and Mass storage, but din know they have Webcam.
Espsi776 WROTE:Thank you all for the advice. If i want to process a low resolution video without a microcomputer, which micro-controller you all will suggest?
robosang WROTE:Thanks brian for the explanation, learn something new today
Low resolution image? You might consider the new CMUcamV4, I just notice Cytron carrying it now. It uses microcontroller from Parallax, the propeller. 8 core (they called it cog) which can do some serious parallel task. I think the code and hardware is open source, should check it out.
