Control and Monitor via SMS
Re: Control and Monitor via SMS
Postby robosang » Sat Nov 24, 2012 8:37 pm
Show some photo....
Postby robosang » Sun Nov 25, 2012 7:48 am
Of course photo of the whole hardware setup :mrgreen:
Postby zhenning » Mon Nov 26, 2012 8:43 am
Check your connection again? Might have mistaken wiring wrongly?
zhenning
Postby robosang » Mon Nov 26, 2012 9:40 pm
Have you tested the modem with computer? Are you using the same modem as in Cytron tutorial?
Postby robosang » Tue Nov 27, 2012 8:11 am
Are you saying you tested the modem with computer and it is working? You need to explain in detailed, that is critical. If you test with computer and it is working, we know is not the modem problem. We can focus on connection from SK40 to modem, which we ask for a photo. Well, experience tell us, everyone will say the connection is the same :mrgreen: until we found mistake, because we make assumption. You might miss something.
Postby Idris » Tue Nov 27, 2012 9:35 am
Look at gsm_send_command function, try remove the rec_data = uart_receive(); in the while(*command!=0) loop.
Postby zhenning » Tue Dec 04, 2012 9:22 pm
madogas WROTE:hi all i try do do any thing to make this project working but no result help me
Need to see your hardware setup like robosang said. You might missed something there. Did the gsm work when you connect to your pc?
zhenning
Postby robosang » Wed Dec 05, 2012 7:28 am
If the modem is working with computer, the modem is working :)
There must be some place wrong.
Postby robosang » Thu Dec 06, 2012 9:22 am
And now you tell us the modem is different from the one shown by Cytron's tutorial? How can we check for you? Not everyone here have a GSM modem. You also need to give us correct link to your modem.
Postby zhenning » Sun Dec 09, 2012 2:32 am
madogas WROTE:hi for all i just try to make the project in http://tutorial.cytron.com.my/2011/12/0 ... r-via-sms/
the modem dosnt response the lcd shows the welcome screen and test com.. and no athor actions i make the priject like i found in the previous web site help me plz iam in dead time of graduation project
I am suspecting there is something wrong from the RS232 to the modem. Please post your codes as well as the terminal screenshot and the photo of your circuit. The faster you give the information needed. The faster people in the chat can narrow your problems down.
Nobody can help you if you keep saying everything is correct and refuse to get a photo of your circuit.
zhenning
