PIC 16F690 with programming (need some advise to rebuild)
Postby wanes » Wed Dec 12, 2012 4:31 pm
flexi-drive.asm
; sample code in Microchip Technology PIC Assembly Language
; to accompany a circuit that controls Flexinol actuator wire
; individual pins RC0-RC3 are brought high for intervals of approximately
; one second and the cycle repeats endlessly
;  initialization - load the standard include file and set the configuration bits
list p=16F690
#include
__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF
                & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
;  variables
UDATA
  CounterA res 1                ; these variables are all used as counters
  CounterB res 1                ; in the delay subroutine
  CounterC res 1
;  Code
CODE 0x00
Start:
   banksel   TRISC
   clrf      TRISC               ; make PORTC all output
   banksel   PORTC
PinCycle:
   movlw     b'00000001'         ; put the bit pattern for the outputs into W
   movwf     PORTC               ; load the bit pattern into PORTC
   call      OneSecondDelay      ; go to the delay subroutine
   movlw     b'00000010'         ; repeat for the next pattern...
   movwf     PORTC
   call      OneSecondDelay
   movlw     b'00000100'
   movwf     PORTC
   call      OneSecondDelay
   movlw     b'00001000'
   movwf     PORTC
   call      OneSecondDelay
   goto      PinCycle
OneSecondDelay:                  ; the delay routine is based on a sequence
   movlw     0x06                ; of nested loops which have been calculated to
   movwf     CounterC            ; take approximately one second to complete
   movlw     0x18
   movwf     CounterB
   movlw     0xA7
   movwf     CounterA
OSDLoop:
   decfsz    CounterA,1
   goto      OSDLoop
   decfsz    CounterB,1
   goto      OSDLoop
   decfsz    CounterC,1
   goto      OSDLoop
   return
end
this is the coding for the PIC 16F690 to control shape memory alloy. but this coding has missing some thing and error when i try to compiled. Some one can help me to solve this problem...
wanes
Re: PIC 16F690 with programming (need some advise to rebuild
Postby zhenning » Wed Dec 12, 2012 6:34 pm
whats the error?
zhenning
Postby shahrul » Mon Dec 17, 2012 8:15 pm
Not many use Assembly Language nowadays.
Postby ABSF » Mon Dec 17, 2012 8:55 pm
Here's the corrected program code.....
   list p=16F690
   #include <P16f690.inc>
   __config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
;  variables
   cblock 0x20
CounterA                 ; these variables are all used as counters
CounterB                 ; in the delay subroutine
CounterC
   endc
;  Code
   ORG 0x00
Start:
   banksel   TRISC
   banksel   PORTC
PinCycle:
   movwf     PORTC
   call      OneSecondDelay
   movlw     b'00000100'
   movwf     PORTC
   call      OneSecondDelay
   movlw     b'00001000'
   movwf     PORTC
   call      OneSecondDelay
   goto      PinCycle
   movlw     0x18
   movwf     CounterB
   movlw     0xA7
   movwf     CounterA
OSDLoop:
   decfsz    CounterA,1
   goto      OSDLoop
   decfsz    CounterB,1
   goto      OSDLoop
   decfsz    CounterC,1
   goto      OSDLoop
   return
   end
Users browsing this forum: No registered users and 26 guests
