PIC16F877 is able to control 10 servo motor speed?
Postby soonlim2 » Sun Dec 23, 2012 12:04 am
Is the PIC mention on topic, is able to control 10 servo speed? Besides the CCP2CON.
soonlim2
Re: PIC16F877 is able to control 10 servo motor speed?
Postby zhenning » Sun Dec 23, 2012 11:25 am
You can manually toggle the pin and use delays or use timers then toggle the pins. Or just get this: http://www.cytron.com.my/viewProduct.ph ... nH3lk/cjI=
zhenning
Postby shahrul » Sun Dec 23, 2012 12:05 pm
You can use Timer Interrupt to control servo motor. If 10 servo, you need 10 PIC pin. Ex Servo Motor.
Or you can reduce PIC pin by using Servo Controller that use 2 UART pin. Ex Servo Controller.
Most important thing, the power supply must support higher current to drive 10 servo.
Postby soonlim2 » Mon Dec 24, 2012 10:32 am
How do I interupt the timer?
soonlim2
Postby shahrul » Mon Dec 24, 2012 10:57 am
soonlim2 WROTE:How do I interupt the timer?
Setting INTCON and OPTION REG for Timer 0. Detail, you see in the datasheet about this 2 register.
Postby zhenning » Mon Dec 24, 2012 10:59 am
Look at project 6: http://tutorial.cytron.com.my/wp-conten ... nual_2.pdf There are some details on timers interrupt.
zhenning
