PIC18F4550 - Stepper motor controlled by potential meter
Postby nicgoh » Tue Jan 15, 2013 2:03 pm
Good day to all respected members in the forum,
I am totally new to this forum and i need help from u guys..
My project that need to to control the stepper motor using potential meter...
Potential meter as the input and output will be the degrees of rotation for the stepper motor...
I am a mechanical student and i am very weak in C programming...
i has got some very fundamental knowledge in C language..
can anyone here please teach me how to control it using PIC18F4550?
can anyone share me the source code of it so that i can refer to? thanks a lot :)
nicgoh
Re: PIC18F4550 - Stepper motor controlled by potential meter
Postby shahrul » Tue Jan 15, 2013 3:21 pm
You need to learn how to use ADC. Then, stepper motor works with pulse, so it's simple to make a pulse, just high and low.
Postby nicgoh » Tue Jan 15, 2013 6:00 pm
i have gone through some tutorial about using ADC from the Cytron website...
cause i am too new in this field.. and none of my lecturers from mechanical know how to do it..
sigh.. do u have some source code for stepper motor and ADC? so that at least i can refer to it and try to make it..
nicgoh
Postby shahrul » Tue Jan 15, 2013 6:12 pm
I don't have free source code. You search on cytron tutorial, read from datasheet and also use google.
Postby gadgetng » Thu Jan 17, 2013 10:53 am
Try to go through this project, NOTE: the potentiometer is used for setting speed.
DIY project PR7
http://www.cytron.com.my/viewProduct.php?pid=HSwOBiUpOBAaOR0OAjEDJfMqSBbl1cpR/xbsOOT6uNc=&store=
Read and start your work. If you are a beginner, just simply use the same PIC of PR7.
gadgetng
Postby Fish Fly » Tue Feb 05, 2013 12:18 pm
four or two coil stepper motor ?
Fish Fly
