problem with pic 16f877a and wavecom modem
Re: problem with pic 16f877a and wavecom modem
Postby shahrul » Wed Feb 06, 2013 7:53 am
Try to not copy-and-paste all the code. You disable some code and make it simpler to PIC just send 'AT' and GSM should be reply 'OK'. Other example GSM Modem.
Postby robosang » Thu Feb 07, 2013 10:03 am
Are you using the same modem as what cytron tutorial use? You should try to communicate the modem with computer to verify the working condition first.
