SC08A with P18F4580
SC08A with P18F4580
Postby twinsleong » Thu Feb 28, 2013 7:48 pm
I've been trying to program the servo controller with the microcontroller 18F4580 but can't seem to get it to work. I'm using MikroC to work this around. I hope you could help point out where my mistake is in doing this,
void main() {
     TRISB = 0X0F;
     UART1_Init(9600);
     // for activating servo channel
     UART1_Write(192);           //select all servo
     UART1_Write(1);             //activate all servo
     UART1_Write(129);           //select all servo
     UART1_Write(62);             //activate all servo
     UART1_Write(32);           //select all servo
     while (UART1_Read() !=0x04){
     //for position and speed command
     while(1){
     if (PORTB.F0 == 0){
     Delay_ms(40);
     UART1_Write(225);           //position & speed command servo 1
     UART1_Write(62);            //higher byte position
     UART1_Write(32);            //lower byte position
     UART1_Write(0);             //servo speed
     if (PORTB.F1 == 0){
     Delay_ms(40);
     UART1_Write(31);            //higher byte position
     UART1_Write(16);            //lower byte position
     if(PORTB.F2 == 0){
     Delay_ms(40);
     UART1_Write(93);            //higher byte position
     UART1_Write(48);            //lower byte position
twinsleong
Re: SC08A with P18F4580
Postby gadgetng » Fri Mar 01, 2013 9:40 am
First i am not familiar with mikroC. Anyway, i used SC08A before. Maybe you can try to start with simple code which just activate the servo. The servo will hold at its position to make sure all the hardware set up is correct before going further to programming.
gadgetng
Postby twinsleong » Thu Mar 07, 2013 12:35 am
Thanks. Found out that the problem was actually due to the board I was using. :oops:
twinsleong
