MCP23S17 weird problem
I was interface LCD and keypad throught I/O Expander MCP23S17.
The code was successful read keypad and display LCD, but the problem is when I off and on it's cannot display.
Below schematic and code.
- CODE: SELECT_ALL_CODE
#define SPI
#define CS RC0
#define LCD GPIOA
#define KEYPAD GPIOB
#define MCP23S17_WRITE 0b01000000
#define MCP23S17_READ 0b01000001
#define IODIRA 0x00
#define IODIRB 0x01
#define IOCONA 0x0A
#define IOCONB 0x0B
#define GPPUA 0x0C
#define GPPUB 0x0D
#define GPIOA 0x12
#define GPIOB 0x13
#define LCD_RS 0
#define LCD_RW 1
#define LCD_EN 2
#define LCD_LIGHT 3
#define LCD_D4 4
#define LCD_D5 5
#define LCD_D6 6
#define LCD_D7 7
#define C1 0
#define C2 1
#define C3 2
#define C4 3
#define R1 4
#define R2 5
#define R3 6
#define R4 7
#include "LibraryHardware.h"
#include "LibraryPeripheral.h"
char lcd_data=0;
void pic_init();
void mcp23s17_init(char trisa, char trisb);
void mcp23s17_write(char address, char value);
char mcp23s17_read(char address);
void lcd_init(void);
void lcd_pulse();
void lcd_write(unsigned char c);
void lcd_goto(unsigned char pos, unsigned char row);
void lcd_string(const char *s);
void lcd_number(unsigned int no, char base, char digit);
char read_keypad(void);
main()
{char keypad;
pic_init(); //initialize PIC
spi1_init(); //initialize SPI
mcp23s17_init(0x00,0x0F); //initialize mcp23s17
lcd_init(); //initialize LCD
for(;;){ //loop forever
keypad=read_keypad();
lcd_goto(0,0);
lcd_string("MCP23S17 HD44780");
lcd_goto(0,1);
switch(keypad){
case 0:{lcd_string(" NO PRESS ");break;}
case 1:{lcd_string(" YOU PRESS 1 ");break;}
case 2:{lcd_string(" YOU PRESS 2 ");break;}
case 3:{lcd_string(" YOU PRESS 3 ");break;}
case 4:{lcd_string(" YOU PRESS 4 ");break;}
case 5:{lcd_string(" YOU PRESS 5 ");break;}
case 6:{lcd_string(" YOU PRESS 6 ");break;}
case 7:{lcd_string(" YOU PRESS 7 ");break;}
case 8:{lcd_string(" YOU PRESS 8 ");break;}
case 9:{lcd_string(" YOU PRESS 9 ");break;}
case 10:{lcd_string(" YOU PRESS 0 ");break;}
case 11:{lcd_string(" YOU PRESS * ");break;}
case 12:{lcd_string(" YOU PRESS # ");break;}
case 13:{lcd_string(" YOU PRESS A ");break;}
case 14:{lcd_string(" YOU PRESS B ");break;}
case 15:{lcd_string(" YOU PRESS C ");break;}
case 16:{lcd_string(" YOU PRESS D ");break;}
void pic_init(){
TRISA=0b00000000;
TRISB=0b00000000;
TRISC=0b10000000;
TRISD=0b00000000;
TRISE=0b00000000;
set_digital();
PORTA=0b00000000;
PORTB=0b00000000;
PORTC=0b00000000;
PORTD=0b00000000;
PORTE=0b00000000;
CS=1;
{int i;
CS=0;
spi1_write(MCP23S17_WRITE); //Write
spi1_write(IOCONA);
spi1_write(0b00110000);
CS=1;
__delay_us(1);
CS=0;
spi1_write(GPPUA);
spi1_write(0b00000000);
CS=1;
__delay_us(1);
CS=0;
spi1_write(IODIRA);
spi1_write(trisa);
spi1_write(trisb);
CS=1;
__delay_us(1);
CS=0;
spi1_write(0x02);
for(i=0;i<=7;i++) spi1_write(0b00000000); //Address 0x02-0x09
CS=1;
__delay_us(1);
CS=0;
spi1_write(0x0E);
for(i=0;i<=3;i++) spi1_write(0b00000000); //Address 0x0E-0x11
CS=1;
__delay_us(1);
CS=0;
spi1_write(GPIOA);
CS=1;
__delay_us(1);
CS=0;
spi1_write(address);
spi1_write(value);
CS=1;
__delay_us(1);
{char data;
CS=0;
spi1_write(MCP23S17_READ); //Read
data=spi1_read();
CS=1;
__delay_us(1);
return data;
void lcd_init(void)
delay_ms(15); //delay for LCD Power Up
lcd_data=lcd_data|(1<<LCD_LIGHT);
lcd_write(0x28); //function set
lcd_write(0x0C); //display on/off control
lcd_write(0x06); //entry mode set
lcd_write(0x01); //clear screen
delay_ms(2);
void lcd_pulse()
lcd_data=lcd_data|(1<<LCD_EN);
mcp23s17_write(LCD,lcd_data);
lcd_data=lcd_data&~(1<<LCD_EN);
if (((c>>4)&1)==1) lcd_data=lcd_data|(1<<LCD_D4);
else lcd_data=lcd_data&~(1<<LCD_D4);
if (((c>>5)&1)==1) lcd_data=lcd_data|(1<<LCD_D5);
else lcd_data=lcd_data&~(1<<LCD_D5);
if (((c>>6)&1)==1) lcd_data=lcd_data|(1<<LCD_D6);
else lcd_data=lcd_data&~(1<<LCD_D6);
if (((c>>7)&1)==1) lcd_data=lcd_data|(1<<LCD_D7);
else lcd_data=lcd_data&~(1<<LCD_D7);
lcd_pulse();
if (((c>>0)&1)==1) lcd_data=lcd_data|(1<<LCD_D4);
if (((c>>1)&1)==1) lcd_data=lcd_data|(1<<LCD_D5);
if (((c>>2)&1)==1) lcd_data=lcd_data|(1<<LCD_D6);
if (((c>>3)&1)==1) lcd_data=lcd_data|(1<<LCD_D7);
lcd_pulse();
delay_us(10);
lcd_data=lcd_data&~(1<<LCD_RS);
switch(row){
case 0:{lcd_write(0x80+pos);break;}
case 1:{lcd_write(0xC0+pos);break;}
case 2:{lcd_write(0x94+pos);break;}
case 3:{lcd_write(0xD4+pos);break;}}
lcd_data=lcd_data|(1<<LCD_RS);
while(*s) lcd_write(*s++);
{char i,j,di[10];
for(i=0;i<=9;i++) di[i]=0;
i=0;
do{
di[i]=no%base;
no=no/base;
i=i+1;}
while(no!=0);
for(j=digit;j>0;j--){
if(di[j-1]<=9) lcd_write(di[j-1]+'0');
else lcd_write(di[j-1]-10+'A');}
{char data,i=0;
mcp23s17_write(KEYPAD,0b11101111);
data=mcp23s17_read(KEYPAD);
if(((data>>C1)&1)==0) i=i+1;
if(((data>>C2)&1)==0) i=i+2;
if(((data>>C3)&1)==0) i=i+3;
if(((data>>C4)&1)==0) i=i+13;
mcp23s17_write(KEYPAD,0b11011111);
if(((data>>C1)&1)==0) i=i+4;
if(((data>>C2)&1)==0) i=i+5;
if(((data>>C3)&1)==0) i=i+6;
if(((data>>C4)&1)==0) i=i+14;
mcp23s17_write(KEYPAD,0b10111111);
if(((data>>C1)&1)==0) i=i+7;
if(((data>>C2)&1)==0) i=i+8;
if(((data>>C3)&1)==0) i=i+9;
if(((data>>C4)&1)==0) i=i+15;
mcp23s17_write(KEYPAD,0b01111111);
if(((data>>C1)&1)==0) i=i+11;
if(((data>>C2)&1)==0) i=i+10;
if(((data>>C3)&1)==0) i=i+12;
if(((data>>C4)&1)==0) i=i+16;
return i;
