need help with SKPS. (Rx & Tx pin)
Postby wheresaly » Thu Apr 11, 2013 3:31 pm
if we connect the SKPS with the PIC16 with UART function..
the wired from SKPS to the PIC should be cross connected rite?
ada voltage tak dkt TX and RX pin tu?
-newbie.
wheresaly
Re: need help with SKPS. (Rx & Tx pin)
Postby shahrul » Thu Apr 11, 2013 3:46 pm
You must understand UART signal. UART is digital, that is '0' and '1' or '0V and '5V'. It not constant voltage. The best to measure it using oscilloscope.
Postby wheresaly » Thu Apr 11, 2013 5:14 pm
but i dont hv any oscilloscope with me.
what u mean is the signal is transmitted constantly rite?
the signal still transmitted even though we didn't press any button at the PS controller?
wheresaly
Postby shahrul » Thu Apr 11, 2013 5:27 pm
wheresaly WROTE:but i dont hv any oscilloscope with me.
Read the SKPS manual. SKPS will transmit data if SKPS receive a command. So, PIC need to transmit first to SKPS, then SKPS will transmit it's data. Ex SKPS.
Postby wheresaly » Fri Apr 12, 2013 2:14 am
ok trima kasih.
nnt sy try buat ye.
nnt sy rujuk dkt SKPS manual.
wheresaly
Postby gadgetng » Fri Apr 12, 2013 9:08 am
wheresaly WROTE:if we connect the SKPS with the PIC16 with UART function..
-newbie.
Yupe. Connect the RX to the TX and TX to RX.
gadgetng
