Uart TX
Uart TX
Postby naixiew » Tue Jul 16, 2013 4:19 pm
hi people,
I'm using Hi Tech C to program my PIC16LF1946.
I have taken the Uart TX and RX code from Cytron to send data from the PIC to my PC via 2 XBees.
Data is sent successfully but the TX pin keeps on transmitting data even though i put it in a for loop that run once.
I even tried to disable TXEN and SPEN after the tranmission but its not working.
Any idea? Sorry though, i cant upload my main file in either .c, .txt or .pdf format.
#define _XTAL_FREQ 16000000
#include <htc.h>
#include "delay.h"
#include "string.h"
__CONFIG (FOSC_INTOSC & PWRTE_ON&WDTE_OFF & MCLRE_ON & PLLEN_OFF & BOREN_ON&WRT_OFF & LVP_OFF&FCMEN_ON & STVREN_OFF & BOREN_OFF&CPD_ON&CP_ON) ;
void InitLCD(void);
void SetChOne(unsigned char ch);
void SetChTwo(unsigned char ch);
void SetChThree(unsigned char ch);
void SetChFour(unsigned char ch);
void SetLCDcol(void);
void transmit(unsigned char data);
void uart_send(unsigned char data)
    while(TXIF == 0);         //wait for previous data to finish send out
    TXREG = data;         //send new data
//function to send string to UART
void uart_string(const char* string)
  while (*string != '\0')
      uart_send(*string++);
      //string++; //point to next character
   uart_send(data);
void uart_str(const char *s)
while(*s)uart_send(*s++); // UART sending string
unsigned char uart_rec(void)      //function to wait for a byte receive from uart
   unsigned char temp;
   while(RCIF==0);               //wait for data to received
   temp=RCREG;
   return temp;               //return the received data
void main(void)
int i=0,labela=1;
unsigned char input;
char tmpstr[]="hello\r";
RCIE=1;
INTE=1;
PEIE=1;
GIE=1;
InitLCD();
//PORTC=0x00;
TRISC=0b11000000;
OSCCON=0b01111010;
SPBRG=103;
RC1STA = 0b10010000;
TX1STA = 0b00100100;
if(labela==1)
uart_string("RTT");
DelayMs(100);
labela=0;
void InitLCD(void)
LCDSE0 = 0xFF;   // enable first group of LCD segment outputs
LCDSE1 = 0xFF;   // enable second group of LCD segments
LCDSE2 = 0x00;
LCDSE3 = 0x00;
LCDSE4 = 0x00;
LCDSE5 = 0x00;
LCDDATA0 = 0;   // clear LCD segment registers
LCDDATA1 = 0;
LCDDATA2 = 0;
LCDDATA3 = 0;
LCDDATA4 = 0;
LCDDATA5 = 0;
LCDDATA6 = 0;
LCDDATA7 = 0;
LCDDATA8 = 0;
LCDDATA9 = 0;
LCDDATA10 = 0;
LCDDATA11 = 0;
LCDDATA12 = 0;
LCDDATA13 = 0;
LCDDATA14 = 0;
LCDDATA15 = 0;
LCDDATA16 = 0;
LCDDATA17 = 0;
LCDDATA18 = 0;
LCDDATA19 = 0;
LCDDATA20 = 0;
LCDDATA21 = 0;
LCDDATA22 = 0;
LCDDATA23 = 0;         // clear LCD segment registers
LCDPS  =  0x60;    //  seems ok, tho check the datasheet once more
LCDCON =  0x89;    //  seems ok.
LCDREF =  0x80;       //    the last part has to be zero, need help in the upper part
LCDCST =  0x00;      //  max contrast
LCDRL  =  0xF0;     //  check it with mr.raj
void SetChOne(unsigned char ch1)
  int temp;
  temp = ch1 ;
   switch(temp)
         case 1:
            SEG15COM1 = 0;  // segment 1A
            SEG14COM1 = 1;  // segment 1B
            SEG1COM1  = 1;  // segment 1C
            SEG0COM1  = 0;  // segment 1D
            SEG0COM0  = 0;  // Segment 1E
            SEG14COM0 = 0;  // Segment 1F
            SEG1COM0  = 0;  // segment 1G
        break;
        case 2:
         SEG15COM1 = 1;   // segment 1A
            SEG1COM1  = 0;   // segment 1C
            SEG0COM1  = 1;   // segment 1D
            SEG0COM0  = 1;   // segment 1E
            SEG1COM0  = 1;   // segment 1G
         break;
        case 3:
            SEG0COM0  = 0;   // segment 1E
         break;
        case 4:
            SEG14COM0 = 1;   // Segment 1F
         break;
        case 5:
            SEG14COM1 = 0;   // segment 1B
         break;
        case 6:
         break;
        case 7:
        break;
        case 8:
         break;
        case 9:
         break;
        case 0:
         break;
         case 'c':
         break;
         case 'P':
         break;
void SetChTwo(unsigned char ch2)
     int temp;
     temp = ch2;
     switch(temp)
         case 1:
             SEG13COM1 = 0;  // Segment 2A
             SEG12COM1 = 1;  // Segment 2B
             SEG3COM1  = 1;  // Segment 2C
             SEG2COM1  = 0;  // Segment 2D
             SEG2COM0  = 0;  // Segment 2E
             SEG12COM0 = 0;  // Segment 2F
             SEG3COM0  = 0;  // Segment 2G
        break;
        case 2:
             SEG13COM1 = 1;  // Segment 2A
             SEG3COM1  = 0;  // Segment 2C
             SEG2COM1  = 1;  // Segment 2D
             SEG2COM0  = 1;  // Segment 2E
             SEG3COM0  = 1;  // Segment 2G
         break;
        case 3:
         break;
        case 4:
             SEG12COM0 = 1;  // Segment 2F
         break;
        case 5:
             SEG12COM1 = 0;  // Segment 2B
         break;
        case 6:
         break;
        case 7:
        break;
        case 8:
         break;
        case 9:
         break;
        case 0:
         break;
         case 'c':
        break;
naixiew
Re: Uart TX
Postby yonghui » Thu Jul 18, 2013 1:53 pm
look at this portion:
void main(void)
int i=0,labela=1;
RCIE=1;
INTE=1;
PEIE=1;
GIE=1;
InitLCD();
//PORTC=0x00;
TRISC=0b11000000;
OSCCON=0b01111010;
SPBRG=103;
if(labela==1)
uart_string("RTT");
DelayMs(100);
labela=0;
can u create a while(1) loop in the main loop, i suspect the main loop keep updating the labela to 1 in this line "int i=0,labela=1;"
so make it like this
main
int i=0,labela=1;
//ur code here:
Re: Uart TX
Postby naixiew » Thu Jul 18, 2013 3:02 pm
hi yonghui,
i have made the adjustment but now the UART wouldnt send anything out. Any more ideas?
Any help is appreciated. :D
#include <htc.h>
#include "delay.h"
#include "string.h"
void InitLCD(void);
// TXREG = data;
// while(PIR1bits.TXIF==0);
// PIR1bits.TXIF = 0;
unsigned char temp;
temp=RCREG;
void main(void)
int i=0,labela=1;
RCIE=1;
INTE=1;
PEIE=1;
GIE=1;
InitLCD();
TRISC=0b11000000;
OSCCON=0b01111010;
SPBRG=25;
RC1STA = 0b10010100;
TX1STA = 0b00100000;
if(labela==1)
uart_str("RTT");
DelayMs(100);
labela=0;
naixiew
